Connecting to a Filezilla Server Using SSL/TLS
joel
I would like to use winscp to automate some uploads to my Filezilla server. If I use regular ftp everything works fine, but when I require SSL/TLS connection on my Filezilla server then winscp just hangs and will not login. Any ideas on how to get this working?
Re: Connecting to a Filezilla Server Using SSL/TLS
