recover files that have been removed due to synchronisation
ppatil
HI
I am newbie user. I sync both the remote with my local directory. unfortunately the remote directory was empty. hence both the remote and the local directories are now empty. is it possible to recover the deleted files from my local directory. i am using version 4.1.7.
Re: recover files that have been removed due to synchronisation
If you have deleting to recycle bin enabled, you may try to search in Windows recycle bin.
