Error Putting 0 Byte File
wobbet
TX
Performing a PUT on multiple files in a directory. Any file that has content is successfully transmitted. Any file that is 0 bytes in length receives an error from WinSCP. In talking to the vendor that I am transmitting files to the 0 byte files were received by the vendor. If I add a single byte to the file using Notepad the file is successfully transferred.
Is this a feature or a defect?
Many thanks!
rjsjr
Re: Error Putting 0 Byte File
nadams1983
Zero Byte Files
I am unable to view zero byte files when logging into a mailbox via WinSCP that are otherwise visible via WS_FTP
Any ideas?
Re: Zero Byte Files
Please post a full log file showing the problem from both WinSCP and WS_FTP.
