Cannot open corresponding panel in opposite directory
Bugsiee
hi.
i've been using winscp for a year now. never had a problem.
using latest version 425.
i am doing nothing different.
today, i get error "Cannot open corresponding panel in opposite directory"
winscp won't/can't open my remote directory.
it asks if i want to create the directory.
if i open the remote directory first, it DOES/CAN open the correcsponding LOCAL directory.
using latest wixxp. server = lamp vps. linux centos, fairly new server. everything was new a year ago.
mdmower
Same issue
I now see that this is the same issue that I have been experiencing and about which I posted a thread. (Sorry for the repeat post, but I didn't see this thread when I searched for "synchronized")
PonchoV
New problem with latest v426. Minor prob. But you may wanna know.
Been using WinSCP over 1 year. Never had this prob before.
When I relaunch WinXP after Standby, I get error:
Assertion failed: random_active > = 0, file putty \SSHRAND.C, line 242
The program crashes/closes after I click the OK button, with another message that tells me:
Abnormal program termination (WinSCP.exe)
I simply restart WinSCP. (No problem.)
PonchoV
Actually, I don't think I was getting this error until AFTER the recent WXP update. Not positive, but I think WinSCP was working fine for a few days there. (No such errors.)
Thanks for your post. This bug is being tracked already.
PonchoV
Pretty cool
It appears the program now (re)connects to remote server *automatically* after you restart Windows from a standby condition. That is pretty cool.
