Loading files is slow (not transfering)
leif
I know there have been a lot of complaints of slow file transfer, I don't have any problem with that.
My problem is that when I open a directory with more then just a couple files it takes a very long time to load them all into the view. The first few (usually enough to fill the window) load just fine, but when I scroll down they start loading in very very slow (like one a second). This happens when viewing files both remotely or locally.
Anybody else have this problem?
Running WinSCP 4.2.5 (build 624) on a 3GHZ Core 2 Duo with 3 gigs of ram. Windows XP Pro.
Tried downgrading to older versions of WinSCP with no change.
Yes, it worked fine for me on my old machine. That's why I tried downgrading, since I had an older version before. When I setup this newer machine I installed the newest version. Can't seem to figure out what the problem is. Running same version of Windows with more ram and processing power. Any ideas would be appreciated.
