put with -delete is working fine local and give error in ser
sunilchitrapu
US
Here is the error i am getting while uploading a file and deleting it at the same time.
Upload command i used after connecting to server is
put -delete C:\Projects\CDS_*.txt
Upload of file 'CDS_12222009.txt' was successful, but error occurre
d while setting the permissions and/or timestamp. If the problem persists, turn
on 'Ignore permission errors' option.
Permission denied.
Error code: 3
Error message from server: This server does not support operations to modify fil
e attributes.
Request code: 9
Please help
Re: put with -delete is working fine local and give error in ser
I hope the error message says what you should do.
Also read this FAQ. If that does not help, come back.
