Problems in connecting with Sco OpenServer
maurososcia
I tried to connect with a server running Sco Openserver 5.
I have correctly loaded all the parameters but in the connection after a fwe seconds il gives me this result :
Error skipping startup message. Your shell is probably incompatible with the
application (BASH is recommended)
Re: Problems in connecting with Sco OpenServer
