Comnand Line support
ChadDa3mon
What would make this perfect is if I could launch it from command line, and supply all the arguments needed via flags. For example:
winscp /h 1.2.3.4 /u <username> /p <password> {/scp|/sftp}.
If we had this support, I'd do my best to get a decent donation made (I'd have to take up a collection).
Re: Comnand Line support
OK, maybe next version. However, do you know that you may create stored session and than pass its name as only command-line parameter?
chrmc1
command line support
Will WinSCP v3.8.2 (build 330) support this? I need application to launch in command line instead of GUI...
