Script open error
steallport
Script open error
Help - I can't see what is different from other implementations I've done.
I have a script:
option batch on
open mysession
cd /var/lib/mysql/unloads
lcd e:\robocopy\mysession-backup\Backupv2
synchronize local
close
I run the command
"C:\Program Files\WinSCP\WinSCP.exe" /console /script= E:\robocopy\mysession-backup\backup2.txt
The "DOS" window opens pauses on Searching for host... for a couple of seconds and then states Host does not exist
The "DOS" box is still open and if I type: open mysession it connects
mysession is configured with the IP as the host, port is 22, username and password are saved and the protcol is is sftp with scp fall back
Anybody got any suggestions why it doesn't connect automatically?
Upgraded from 4.0.x to 4.1.9 on a windows 2003 server
Re: Script open error
Remove the space after "/script=".
