CRLF question
mohanr
CRLF question
Even in binary mode the server admin. is reporting that '0D 0A' is present in the file even though '0D' is removed here with a hex editor. What could go wrong while transmitting the file ? Is this a known issue ?
I thought that binary mode does not touch the file.
Re: CRLF question
Sure it does not. So if the file is indeed modified, there has to be another problem.
mohanr
Re: CRLF question
I have sent a mail with Logs. I don't see '0D' in the bytes printed in the logs. So it seems to some other problem.
A file generated using Java can have a eof. A CTRL Z( EOF ) at the end of file is also reported by the server admin. Even this is not seen in the logs. I think it is 1A
CRLF question
It is funny that even though the WinSCP logs show the bytes without the 0D character the linux admin is still complaining.
