FTP Server timestamps without seconds
xyz123
WinSCP doesn't show the seconds in the modification time on the FTP server I'm unsing. When using for example FileZilla I can see the seconds so the server has that information. Is there a way to enable it or can it be fixed in a future version?
It gives me troubles when synchronizing local and remote files edited within the same minute.
Re: FTP Server timestamps without seconds
Please post a log file both from Filezilla and WinSCP?.
