Unable to log into alternate account on same server.
mrhope
Utah
I'm able to log into a main account on my server, however unable to connect with another account. The server is using TLS encryption on FTP.
I can log into "hope" account and get the below output, however the other account username: "name@domain.com" doesn't seem to be accepted. I've also tried connecting through the command prompt using: "open name40domain.com:password@domain.com" and still am unable to connect.
I verified it's not the account by trying FileZilla and it's capable of logging into both accounts with no issues.
Any help on deciphering this problem would be appreciated.
Re: Unable to log into alternate account on same server.
Can you post a log file both from Filezilla and WinSCP?
