File permissions - windows to unix
robatwork
UK
I am uploading a file (both with a script and manually in winscp) from a windows server to a unix server.
No matter what options I choose in Preferences/Transfer, I always get the file transferred as rw-r--r--
I can manually change permission however to eg rwxr-xr-x
If I manually change permissions, the upload the same file again and overwrite, then the changed permissions stay. If I delete the file then upload, it goes back to rw-r--r--
Any ideas how I can force permissions automatically or why it isn't working?
Am using 4.2.2 build 480
many thanks
Rob
robatwork
UK
Follow up - I have discovered the permission= option inthe script, but it doesn't seem to work:
Synchronize remote -mirror -delete -criteria=size -permissions=755
This does the synchronize but permission of the files are still rw-r-r ie 644
Any ideas what I am doing incorrectly?
(Having searched for similar problems I think this issue should be moved to the scripting forum please)
thanks
Re: File permissions - windows to unix
robatwork
UK
Hi - here is the log:
. 2009-12-03 08:13:09.593 --------------------------------------------------------------------------
. 2009-12-03 08:13:09.593 WinSCP Version 4.2.2 (Build 480) (OS 5.2.3790 Service Pack 1)
. 2009-12-03 08:13:09.593 Login time: 03 December 2009 08:13:09
. 2009-12-03 08:13:09.593 Session name: test_ftp
. 2009-12-03 08:13:09.593 Host name: xxx(Port: 21)
. 2009-12-03 08:13:09.593 User name: xxx(Password: Yes, Key file: No)
. 2009-12-03 08:13:09.593 Tunnel: No
. 2009-12-03 08:13:09.593 Transfer Protocol: FTP
. 2009-12-03 08:13:09.593 Ping type: C, Ping interval: 30 sec; Timeout: 60 sec
. 2009-12-03 08:13:09.593 Proxy: none
. 2009-12-03 08:13:09.593 FTP: FTPS: None; Passive: Yes
. 2009-12-03 08:13:09.593 Local directory: c:\test_ftp, Remote directory: /httpdocs/upload/images/test_ftp, Update: No, Cache: Yes
. 2009-12-03 08:13:09.593 Cache directory changes: Yes, Permanent: Yes
. 2009-12-03 08:13:09.593 DST mode: 1
. 2009-12-03 08:13:09.593 Connecting to hughrice.net ...
. 2009-12-03 08:13:09.656 Connected with hughrice.net. Waiting for welcome message...
< 2009-12-03 08:13:09.812 220 ProFTPD 1.3.1 Server (ProFTPD) [192.168.1.175]
> 2009-12-03 08:13:09.812 USER xxxxx
< 2009-12-03 08:13:09.968 331 Password required for xxxxx
> 2009-12-03 08:13:09.968 PASS ********
< 2009-12-03 08:13:10.140 230 User xxxxxx logged in
> 2009-12-03 08:13:10.140 SYST
< 2009-12-03 08:13:10.218 215 UNIX Type: L8
> 2009-12-03 08:13:10.218 FEAT
< 2009-12-03 08:13:10.234 211-Features:
< 2009-12-03 08:13:10.234 MDTM
< 2009-12-03 08:13:10.234 REST STREAM
< 2009-12-03 08:13:10.234 SIZE
< 2009-12-03 08:13:10.375 211 End
. 2009-12-03 08:13:10.375 Connected
. 2009-12-03 08:13:10.375 --------------------------------------------------------------------------
. 2009-12-03 08:13:10.375 Using FTP protocol.
. 2009-12-03 08:13:10.375 Doing startup conversation with host.
> 2009-12-03 08:13:10.375 PWD
< 2009-12-03 08:13:10.390 257 "/" is the current directory
. 2009-12-03 08:13:10.390 Changing directory to "/httpdocs/upload/images/test_ftp".
> 2009-12-03 08:13:10.390 CWD /httpdocs/upload/images/test_ftp
< 2009-12-03 08:13:10.406 250 CWD command successful
. 2009-12-03 08:13:10.406 Getting current directory name.
> 2009-12-03 08:13:10.406 PWD
< 2009-12-03 08:13:10.437 257 "/httpdocs/upload/images/test_ftp" is the current directory
. 2009-12-03 08:13:10.437 Startup conversation with host finished.
. 2009-12-03 08:13:10.437 Collecting synchronization list for local directory 'c:\test_ftp' and remote directory '/httpdocs/upload/images/test_ftp', mode = 0, params = 5635
. 2009-12-03 08:13:10.437 Retrieving directory listing...
> 2009-12-03 08:13:10.437 TYPE A
< 2009-12-03 08:13:10.453 200 Type set to A
> 2009-12-03 08:13:10.453 PASV
< 2009-12-03 08:13:10.468 227 Entering Passive Mode (78,136,8,75,145,60).
> 2009-12-03 08:13:10.468 LIST -a
< 2009-12-03 08:13:10.515 150 Opening ASCII mode data connection for file list
< 2009-12-03 08:13:10.703 226-Transfer complete
< 2009-12-03 08:13:10.703 226 Quotas off
. 2009-12-03 08:13:10.703 Directory listing successful
. 2009-12-03 08:13:10.703 Synchronizing local directory 'c:\test_ftp\' with remote directory '/httpdocs/upload/images/test_ftp/', params = 5635
. 2009-12-03 08:13:10.703 Deleting file "/httpdocs/upload/images/test_ftp/67-04-002.jpg".
> 2009-12-03 08:13:10.703 DELE /httpdocs/upload/images/test_ftp/67-04-002.jpg
< 2009-12-03 08:13:10.718 250 DELE command successful
. 2009-12-03 08:13:10.718 Copying 1 files/directories to remote directory "/httpdocs/upload/images/test_ftp/"
. 2009-12-03 08:13:10.718 PrTime: Yes; PrRO: No; Rght: rwxrwxrwx; PrR: Yes (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask: *.*
. 2009-12-03 08:13:10.718 TM: M; ClAr: Yes; CPS: 0; ExclM(No):
. 2009-12-03 08:13:10.718 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-12-03 08:13:10.734 File: "c:\test_ftp\Blank.txt"
. 2009-12-03 08:13:10.734 Copying "c:\test_ftp\Blank.txt" to remote directory started.
. 2009-12-03 08:13:10.734 Ascii transfer mode selected.
. 2009-12-03 08:13:10.734 Starting upload of c:\test_ftp\Blank.txt
> 2009-12-03 08:13:10.734 TYPE A
< 2009-12-03 08:13:10.750 200 Type set to A
> 2009-12-03 08:13:10.750 PASV
< 2009-12-03 08:13:10.765 227 Entering Passive Mode (78,136,8,75,155,114).
> 2009-12-03 08:13:10.765 STOR Blank.txt
< 2009-12-03 08:13:10.812 150 Opening ASCII mode data connection for Blank.txt
< 2009-12-03 08:13:11.031 226 Transfer complete
. 2009-12-03 08:13:11.031 Upload successful
. 2009-12-03 08:13:11.031 Disconnected from server
After the transfer the directory looks like this:
sorry it didn't upload well but you can see the permissions are rw-r--r-- on the two files uploaded.
Here is the batch file that initiates the transfer:
winscp.exe /console /script=ftp.txt /log=c:\log.txt
and here is ftp.txt:
option batch on
open test_ftp
Synchronize remote -mirror -permissions=777 -delete -criteria=size
Many thanks for any help you can offer
robatwork
UK
Follow Up:
Using the parameters above I uploaded to a folder with some existing files. The ones that were already there were updated, and kept their rwxrwxrwx permissions. The brand new files still got rw-r--r--
Can you help please?
thanks
I wasn't aware that you use FTP protocol. With FTP the option is not supported for put command. I have updated documentation to reflect that. You can use chmod command though.
