Unable to log into ftp server with password
bgwiles
Maryland
Keep getting Host Does Not Exist
This is the file that I am using with UN, PW and server changed to protect the innocent.
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
# open user:password@example.com
# Connect
open sftp://USERNAME:password@ftp3.server.com
# Change remote directory
cd /Exports
# Force binary mode transfer
option transfer binary
# Download file to the local directory c:\ulti
get filename.txt c:\ulti\
# Disconnect
close
# Exit WinSCP
What am I missing. I need to run a command line that gets the file in the remote folder every 15 minutes.
bgwiles@...
Re: Unable to log into ftp server with password
Can you ping the ftp3.server.com (or whatever the real hostname is)?
Yes, I am also able to open the server with the GUI process. If I use the winscp.com statement I can use the "open" statement syntax without the password, "open sftp://USERNAME@ftp3.server.com" and then type the password when prompted, but it will fail everytime when I add the password. (open sftp://USERNAME:password@ftp3.server.com )
bgwiles@...
"/" in password
I may have found the problem, but still need a solution. I see in one of your FAQ's that WinSCP cannot accept special characters in a password from the command-line. Here is an example of the password that is being used: eaR#S/92zUj. I may not be able to have the vendor change their password, is there a work around that can be used?
Re: "/" in password
The FAQ, you probably refer to, shows how to deal with the problem:
eaR#S%2F92zUj
Christiaan
Special characters in FTP password
Hi all
I have a customer FTP site that I need to upload a file to, but the password has the @ sign in it.
How would you type a password like P@55W0rd, with the %40 as the ASCII input.
Thank you in advance!
Re: Special characters in FTP password
Please read FAQ. If that does not help, come back.
Hi Martin, Did get the info off the FAQ.
I enter the password as P%4055W0rd, but it still asks for a password. From the Linux command line, it works fine, without the ASCII translation.
Any ideas would be welcome.
Thanks again.
Christiaan.
Thanks again.
Christiaan.
UPDATE: Using WinSCP, I logged into my own Linux ftp server using a "normal" password with the @ sign. That should not have worked, but it did....
Seems the FTP server that I'm trying to get into, has issues..
Regards
Christiaan.
