Minor: '&' is not rendered in the Transfer settings presets
dandv
1. Create a transfer setting preset names "Exclude .svn & co"
2. View it in the list of Preferences -> Transfer -> Presets. The '&' sign will not appear.
Re: Minor: '&' is not rendered in the Transfer settings presets
That's actually by purpose. & is used to prefix keyboard accelerator that you can then use to select the preset in menus. What's wrong that if you escape the & by doubling it, it still won't show in the list.
