Suggestion for Setup Routine
gebhard
I'd suggest to have an option during setup to set all transfers to binary (should default to automatic to have the normal behavior and please inexperienced users).
Reason: the auto transfer decision binary vs text is fine for most users - but for some professional usage you need every transfer to be binary. So it would be very nice to be able to set this option during set up (e.g. on the screen where the command interface is configured to be nc or explorer).
Thanks,
Gebhard
Re: Suggestion for Setup Routine
I'm sorry, but this would end up with having all configuration duplicated in setup. Other will obviously find other options important enough to be in setup already.
