List index out of bounds (-1) - winSCP 4.2.4 (610)
chrissmiss
I'm using winSCP 4.2.4 (Build 610)
Using "Custom Command"
ln -s ../sites-available/xy-domain.de
or
ln -s ../var/lib/vservers/cewww/var/www/
I get the Error:
(EStringListError) List index out of bounds (-1)
Re: List index out of bounds (-1) - winSCP 4.2.4 (610)
