Using WinSCP to transfer files by SFTP, errors
Brent_badger
NC
If I transfer files manually from my local directory to the FTP remote site, there are no errors. However, if I execute this command from the command line:
put C:\edi810\810_091105.* /tovan/edi
I get an error that says "Can not execute put command."
I am using WinSCP 4.2.1 and am using TLS Explicit Encryption.
What am I missing? I would very much like to automate this transfer, but I can't even get the basic commands right.
Re: Using WinSCP to transfer files by SFTP, errors
There's no such error message in WinSCP. Where do you execute the command from actually?
Brent_badger
NC
YES THERE IS!!!
I go to the WinSCP window, logged into the FTP site.
Where it says "Command>" I type in:
put C:\edi810\810_091109* /tovan/edi/*.edi
I hit Enter.
A message box comes up and says "ERROR: CAN NOT EXECUTE PUT"
[/b]
Sorry, there's no 'command>' prompt in WinSCP. I really have no idea what you mean. Can you post a screenshot?
Any chance you mean the console window?
