Can't open home file to copy to remote
george
I'm getting a pop box that says my file can't be opened to copy to the remote. The file is in .html format edited by MS word 2002. I was reviously using Visual Page & saving in .html format & those file copied perfectly. My new Windows XP won't run Visualpage or I would still be using it. Any Ideas??
Re: Can't open home file to copy to remote
Is the file still opened in Word while you try to upload it? Word locks opened file. This prevents other application to use it.
