Error - Message too long to send to a console
manustone
Hi all
today I run a script from WinScp and at some point I received the following message
MESSAGE TOO LONG( 53006 bytes ) To SEND To A CONSOLE and WINScp exit with an error code.
What can i do to increase this buffer size? Is there any fix in place?
MNST
lcgonzal
argentina
Re: Error - Message too long to send to a console
I have sent you an email with link to a debug version.
Please send to me this link for fix this error case.
by email or public in this topic.
Thank you very much for all!
Sent.
Re: I'm having this same issue
dgosche wrote:
Can I get the link also
ajFA
Same issue - help?
Hi Everyone, was a fix released for this? I also am occasionally getting this error on a certain FTP server:
Copying files from remote side failed.WinSCP.SessionRemoteException: Message too long (164199 bytes) to send to external console.
Do I need a debug version to fix, or were one of you able to fix without running a debug instance of WinSCP (note I'm using the .COM/.DLL plugin). Running inside a .NET console application.
Was the fix making a custom build from the debug, or is there some sort of setting to allocate more buffer space to receive messages from the server.
Thanks,
Austin
Re: Same issue - help?
aldass
Lombard, IL
Can you please send me the debug version as well?
I've sent you a dev version with a fix.
alexd85
United States
Can I please get a copy of this dev version as well? (Winscp.com)
Thanks!
Sent.
