Copy remote path+filename to clipboard
Peter Barrs
Hi, thanks for your quality software - it allows me to work from home.
I need to tell people where I have uploaded files. Is there an easy way to select a file and copy its path+filename to the clipboard.
Thanks!
Re: Copy remote path+filename to clipboard
No it is not. But it is good idea, I'll add the feature to next version.
Temporary solution: To copy current directory path, you may open "Open directory" dialog (Ctrl+O) and copy the current path from its input box. To copy file name, press F2 (for rename).
