copying files larger than 10 mb fails
robbert
Netherlands
"C:\Program Files\WinSCP3\winscp.exe" /console /command "open scp://Administrator:xxxx@xx.xx.xx.xx" "synchronize local backup /cygdrive/c/www"
works perfect, except for files larger then ca 10MB
when winscp starts to copy a large file, winscp aborts within a few seconds
-copying fataly failed
-network error
version 424
SCP
windows xp sp3
remote windows 2003 server
i installed 419 and the problem was solved
Re: copying files larger than 10 mb fails
