Error, after Windows Upgrade from Vista to 7!
princemichi
since i have upgradet my pc to windows 7 i recive the following error when i start WinSCP:
Can i do anything to fix this problem?
Thank You and Best Regards,
PM
www.mumb1e.de
Re: Error, after Windows Upgrade from Vista to 7!
Thanks for your post. This issue is being tracked already.
theSaint
Does not Work with latest beta nor latest stable
Hi everybody,
i've searched this bug today and it supposed to be fixed in 4.2.2. But... i'm running 4.2.4 Build 610 on Windows 7 64 Bit and the same error still appears.
I tried to run winscp with a compatibility layer win xp sp3, but with no effect. Is there a solution i've not found yet?
Thanks and have a nice weekend.
(Sorry for bad english, its not my mother tongue)
Re: Does not Work with latest beta nor latest stable
