File transfer not shown when using remote console tool
nsilva
I need to use WinSCP.com on another computer using the PSTools program to execute processes remotely.
When I use WinSCP.com this way I can't see the file transfer evolution. :cry:
The same this happens if I use WinSCP.com with another remote console program like the DameWare remote console.
It's something wrong when WinSCP is sending the file transfer progress to the PIPE?
It's possible to have a option to show the progress in another way?
Re: File transfer not shown when using remote console tool
WinSCP.com does print progress on screen only, not when output is redirected to pipe or file.
nsilva
Sugestion: Add a option to show and send to the pipe a character that represent the transfer of n bytes. For example like the hash option of ftp command of Windows. :wink:
