check for transmission error
Schnulla
Does WinSCP some kind of transmission error checks?
For example I'm just uploading a 400 MB file to
my server using FTP over explicit SSL and I want
to be sure that the transferred data (bits) are
transferred without errors.
But I don't want to run a md5 or sha on the
server after the upload so my question is,
are there any checks during the transfer?
Thanks!
Schnulla
oh great after several hours of uploading this
400 MB file winscp just frozed at 99% with
"not responding" window...
where can I get error logs?
Re: check for transmission error
Depends on protocol. It is kind of implicit fro SSH (SFTP and SCP).
Schnulla
Ah ok, and for for FTPS?
Thanks!
