Scripting Unknown Command Error
evick
Puerto Rico
Good evening to the community,
In the last three month in the place where I work integrate some old systems with new ones.
One of the good tools that we use its WINSCP 4.1.6, in the last month I create a script and call it from a bat file and works perfect in a Windows 2000 Server SP3 for create automation process.
I been a couple of hours trying to make the same in Windows XP SP3 and its
works and you see the Command window running but it come to a place where say Unknown Command.
First I notice that the default installation path is c:\program files\winSCP\ and the error say unknown command c:\program , there I decide to change the install path just to be sure that's not the problem. I install it here c:\winscp But it continues giving me the same error.
If someone have a working around or a solution to this problem its going to be a huge help.
Thanks a lot
--evick
Reply with quote E-mail
evick
Puerto Rico
Re: Scripting Unknown Command Error
Can you post your batch file?
Yes, Thanks a lot
The .bat file
"C:\WinSCP\winscp.exe" /console /script=TRANSFER_BACKUP.txt BACK
The Script
option batch on
option transfer binary
get *.* D:\BACKUP\
close
Thanks for any help that may provide
--evick
evick wrote:
The Script
option batch on
get *.* D:\BACKUP\
close
The highlighted part is probably cause of your problem.
