- vallexa2
- 1
Cannot start WinSCP application
Kintar
Cannot Start WinSCP Application
Site Admin -
- 43,071
- Prague, Czechia
Re: Cannot start WinSCP application
mmerlone
yes, but...
- mmerlone
- 3
- Curitiba , PR, Brasil
Re: yes, but...
.. I was using 4.1.9 just fine without this error, this started occuring when upgraded for latest beta 4.2.4 (build 610). That beta was installed with the checkbox to make a full upgrade using previous versions, so something went wrong with the installer.
Oops... on "...upgrade using previous versions..." please read "...upgrade using previous options...". Sorry.
And yes, I have both winscp.xe and winscp.com on same folder, and still dont work.
- apurva
- 4
I don't plan to read the complete documentation of winscp at every minor release of it.
Site Admin -
- 43,071
- Prague, Czechia
Re: yes, but...
Can you run the winscp.exe?And yes, I have both winscp.xe and winscp.com on same folder, and still dont work.
What path are the file in?
what is you version of Windows?
- mmerlone
- 3
Re: yes, but...
Yes.Can you run the winscp.exe?And yes, I have both winscp.xe and winscp.com on same folder, and still dont work.
The non-beta were installed by next-next-finish mostly using defaults, checked to register on %PATH% (verified ok) and to handle sftp:// and scp:// addresses. Upgraded to beta doing a full upgrade (recommended), and both executables are on C:\Program Files\WinSCP.
It is a Windows 2008 Server Standard SP2 (not R2).
Site Admin -
- 43,071
- Prague, Czechia
Re: yes, but...
I've sent you an email with debug version.The non-beta were installed by next-next-finish mostly using defaults, checked to register on %PATH% (verified ok) and to handle sftp:// and scp:// addresses. Upgraded to beta doing a full upgrade (recommended), and both executables are on C:\Program Files\WinSCP.
- mmerlone
- 3
Re: yes, but...
I've downloaded, extracted and overwrited the one installed on my server. That one works without a problem.
To shed some light on what I am doing, this is a MS-Sql server and I have to copy its dumps to a linux box where I have a tape driver to backup. On the MS-server, I have those scripts, which will be scheduled to run from the sql engine:
scp10.cmd:
f: cd f:\mssql\ winscp.com /script=scp10.script rem pause
scp10.script:
option batch on option confirm off open user@server.domain.tld put F:\mssql\DBTeste_1000.bak put F:\mssql\DBProducao_1000.bak put F:\mssql\DBHomologacao_1000.bak exit
CXT
We are having a similar issue.
comj
same issue, trouble with command line
I'm trying to follow https://winscp.net/eng/docs/guide_automation_advanced and it will not work because of this.
comj
launching winscp com
- Holly Glaser
- 6
- Seattle
WINSCP.COM does not open from windows 7 workaround
Winscp script error version 4.2.5.build 624
Problems
1. Windows cmd window does not recognize winscp
ex. C:> winscp.exe
'Winscp' is not recognized as an internal or external command,
operable program or batch file.
2. Winscp console does not open scripts using > winscp.exe /console /script= myscript.txt
>Unknown command 'winscp.exe'
Workaround:
This is not acceptable for end users
1. open install folder
2. double click on winscp.com to open console
3. type in each command manually
iam able to connect using the stored session and upload files etc, How can I run this as a scripot?
TIA 8) >
Site Admin -
- 43,071
- Prague, Czechia
Re: We are having a similar issue.
Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.I installed Winscp 4.2.5 fresh on a Windows 2008 R2 it will not run from the command line. I continue to get the "Cannot start the winscp application". I have tried removing and re-installing, but no luck at this point.
Site Admin -
Re: same issue, trouble with command line
You need to have winscp.exe in the same directory as winscp.com.If you launch a command prompt in Windows XP and enter "winscp.com" and hit enter you get "Cannot start WinSCP appliaction". No problem with exe, but it appears exe can't script like the com can.
Site Admin -
- 43,071
- Prague, Czechia
Re: WINSCP.COM does not open from windows 7 workaround
Well, I support you do not have winscp.exe in the PATH.1. Windows cmd window does not recognize winscp
ex. C:> winscp.exe
Why do you suppose this should work?2. Winscp console does not open scripts using > winscp.exe /console /script= myscript.txt
You need to run that command from Windows command line, not from WinSCP console.
- Holly Glaser
- 6
- Seattle
This is my first winscp script, and I am confused although I've been reading the docs.
I added winscp to the path(below)and it fixed my problem. As usual, there is now a different error and I am TIA for your advice.
from the windows cmd
C:\>winscp.exe This works to start the GUI
However,this does not open the winscp console
C:\>winscp.com
Cannot start WinSCP application.
My questions-
Can I start a script from the winscp console? Or is it only for writing scripts and manual commands?
Can I run a winscp script from the GUI?
This would be best for the user.
The revised Path:
%CommonProgramFiles%\Microsoft Shared\Windows Live;C:\QuantumGIS\apps\gdal-16\bin;C:\QuantumGIS\bin;C:\Program Files (x86)\JavaFX\javafx-sdk1.2\bin;C:\Program Files (x86)\JavaFX\javafx-sdk1.2\emulator\bin;C:\Perl\site\bin;C:\Perl\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\Common Files\Intuit\QBPOSSDKRuntime;C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;c:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\QuantumGIS\apps\msys\bin;C:\QuantumGIS\apps\grass\grass-6.4.0svn\bin;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\WinSCP
Holly
ex. C:> winscp.exe
DeadMoneyDan
Workaround
However when executing from the command line, I got the dreaded "Cannot start WinScp application" message. I worked around it using the following command before attempting to start WinSCP:
cd /d C:\Program Files (x86)\WinSCP
...even though C:\Program Files (x86)\WinSCP is in the path.
Mr. Prikryl, I have to disagree with you. This has nothing to do with Documentation. I is a bug. :evil:
DeadMoneyDan
Workaround - Stranger, yet more effective
I reverted to the 4.1.9 version of the com. It seems to work fine with the 4.2.5 exe and solves my problems. :idea:
- Holly Glaser
- 6
- Seattle
Re: Workaround - Stranger, yet more effective
1. My 4.2.5 is installed in the C:\Program Files (x86)\WinSCP also.
2. On startup, there is an error message cannot find winscp/ocsetu~
Here is something strange--
Attempt to open a winscp script from windows cmd
C:\>winscp.exe /console /script="winscp_open_stored_session.txt"
The result is that a black window appears briefly and then goes away. probably the winscp.com window.
Hmmmmmmm. ideas?
Holly 8)
Changing the directory to C:\Program Files (x86)\WinSCP to run WinSCP.com works, yes, but breaks a lot of scripts.
DeadMoneyDan
Try using WinSCP.com not the .exe from the command line. If WinSCP won't start, refer to my last two posts.
comj
I'm using the default install and therefore I have both exe and com in same directory.
Site Admin -
- 43,071
- Prague, Czechia
OK, so if you use 4.2.5 exe and com, it does not work. But if you use 4.1.9 com and 4.2.5 exe in a same way it does work. Right? This is possibly related to 64-bit OS as I haven't seen the problem before.Changing the directory to C:\Program Files (x86)\WinSCP to run WinSCP.com works, yes, but breaks a lot of scripts.
comj
Jivey
Winscp.com and winscp.exe
Can not find "Cannot start WinSCP application."
I have c:\program files\winscp\ in my path which has both winscp.com and winscp.exe
If I call winscp.com directly c:\program files\winscp\winscp.com it works :)
If I call winscp.com from c:\ I get the error :(
If I call winscp.com from c:\ and copy winscp.exe to the root of c:\ it works :)
The issue is that when calling winscp.com it find it in the path, but only looks at the current directory for winscp.exe.
Suggestion - I do not have a fix, but if the developers used a unique environmental variable to point to winscp.exe that could fix the path issue.
danh
Jivey is a good troubleshooter
I am a fresh evaluation install of 4.2.5 (Build 624)
The workaround is always specifying the path in the command. Either of these should work.
C:\Program Files\WinSCP\>WinSCP
or
C:\>"c:\Program Files\WinSCP\WinSCP.com"
phried319
Re: Jivey is a good troubleshooter
That worked straight up cash money for me. THANKS!Same issue here, and it appears Jivey is right. It appears WinSCP.com only looks in its current directory for WinSCP.exe; it does not appear to search the PATH if WinSCP.exe isn't found.
or
Site Admin -
- 43,071
- Prague, Czechia
Can anyone (everyone) send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
tdalsimer@...
I wasn't able to reproduce this problem using any of the scenarios described here. So really need someone to help me with debugging. Otherwise I hardly fix this.
- Guest
I also need the debug version of winscp as I am having the same problem
- dangdude
- 1
- Missouri
note FIXED in 4.2.6
This is FIXED in 4.2.6, Feb 2010 -- see history for 4.2.6, Tracker Bug 542.
Thanks!!!
T_T
under system variables>path - edit: add ";C:\Program Files\WinSCP"
mcc99
I have the Winscp ver4.2.3 build 494 application and Windows XP Professional ver 2002 with SP2. When i try to start winscp.com (c:\winscp.com or c:\winscp or c:\winscp.com open or c:\winscp.com /script=syncftp.txt) from the command line on the screen the message "Cannot start WinScp application" is shown always. I need help (Excuse for my English).
Old thread, but prob persists in current ver of WinSCP, 5.9.5, build 7441. Seems WinSCP.com is not the go-to launcher anymore but rather WinSCP.exe itself. (My OS: Windows 10 ver 1703). The following works like a charm for me:
cd C:\path\dest_dir
"C:\path\WinSCP\WinSCP.exe" /script=C:\path\script.txt
script.txt looks like this:
option echo off
option batch on
open ftp://userid:password@www.mysite.com
cd /
option transfer binary
mget filename*.*
rm filename*.*
close
Easy-peasey. Logs into the site, cds to /, retrieves indicated file(s) into C:\path\dest_dir, delets the remote files retrieved from the site, then closes the connection and exits WinSCP.
Site Admin -
- 43,071
- Prague, Czechia
"C:\path\WinSCP\WinSCP.com" /script=C:\path\script.txt
Do you get "Cannot start WinSCP application"?
Abdullah_ARSLAN
I put winscp.exe and winscp.com into system32 folder.
When I open cmd and just execute "winscp.com /script=C:\TOOLS\WinSCP-5.9.6-Portable\testscript.txt"
I get error "Cannot start WinSCP application"
When I run "C:\PathToWinscp\winscp.com /script=C:\TOOLS\WinSCP-5.9.6-Portable\testscript.txt"
it works.
So, I cant run it witouth path? It is in the path.??
Site Admin -
system32 in the first place? That does not sound like a good idea.
Anyway, assuming your system in 64-bit, you would have to use a hidden folder
sysnative instead, as WinSCP is 32-bit application.
Bud do not do that!
