Wildcard use in scripts
apurva
I am trying to get filename from different directories. To do that I am using the following command in my script
get "/abc/jkl/com?/stats" c:\logs\
Scenario is that there are folders by name com1, com2, com3 etc.. and I am interested only in the "stats" file in each directory.
The above command gives me
Error listing directory '/abc/jkl/com?'
I haven't even reached the second part of using Operation masks to store the several stats file as "stats.com1", "stats.com2" etc.
Using version 4.2.3 build 494
Re: Thanks
You can list the directories, parse it with some script to generate WinSCP script file for downloading specific files. See this example for similar task.
