Copy a directory with a space in its name
moshikofeldman
I'm trying to use the following command to copy a folder from a Windows machine to Linux:
source: d:\my test
target: /root/Desktop
> winscp.com myuser:mypass@1.2.3.4 /command "put d:\my test /root/Desktop/"
(It is important to say that the same command works with a simple source folder name, such as d:\test)
it fails, of course, and reports that the folder "d:\my" doesn't exist.
I've tried some variations, such as
> winscp.com myuser:mypass@1.2.3.4 /command "put \"d:\my test\" /root/Desktop/"
but none of them works. How can I quote the source folder name inside a put command, in order for it to be understood correctly?
Thank you!
Re: Copy a directory with a space in its name
Double them.
And make sure you open the session using open command as well.
winscp.exe /console /command "open myuser:mypass@1.2.3.4" "put ""d:\my test"" /root/Desktop/"
Apurva
Similar problem but with hostkey
I am using the following command:
>winscp.com /command "open username:pwd@host:22 -hostkey="ssh-dss 1024 b0:ed:e0:fg:cd:55:f6:6c:cf:ff:70:ed:68:bc:3e:1c""
It first does not take the hostkey and give me
Unknown command '1024'.
Unknown command 'b0:ed:e0:fg:cd:55:f6:6c:cf:ff:70:ed:68:bc:3e:1c'
I've tried doubling the quotes like this
>winscp.com /command "open username:pwd@host:22 -hostkey=""ssh-dss 1024 b0:ed:e0:fg:cd:55:f6:6c:cf:ff:70:ed:68:bc:3e:1c"""
and I get the error - too many parameters for command 'open'
Re: Similar problem but with hostkey
First make sure you use the latest version. Then, the double-quoting does not work with winscp.com yet. See tracker.
