Connection has been unexpectedly closed
seb
hi,
I am a problem with bash scripting.
when I launch a my script , i have a error next :
Connection has been unexpectedly closed. Server sent command exit status 0.
with winscp.com a batch command work and GUI winscp work.but a batch script no work.
help me,
Re: Connection has been unexpectedly closed
