Trouble downloading filename with spaces
omarrodriguezt
Dominican Republic
Thank you for this great sofware!!!
I had develop an script that works great, except if I try to download a filename with spaces.
Here is the command line:
/command " option batch abort " " option confirm off " " open sitename " " get /folder/my text file.zip C:\tmp\*" exit
After running the script I get following in console:
Error code: 2
Error message from server: No such file
Request code: 7
Using WinSCP 4.2.3 on Windows XP
I was reading https://winscp.net/eng/docs/commandline#syntax and I found:
winscp.exe /console /command "option batch on" "open ""session with space"""
And I tried:
/command " option batch abort " " option confirm off " " open sitename " " get ""/folder/my text file.zip"" C:\tmp\*" exit
/command " option batch abort " " option confirm off " " open sitename " " get ""/folder/my text file.zip C:\tmp\*""" exit
No luck with either. Thank you in advance.
Re: Trouble downloading filename with spaces
omarrodriguezt
Dominican Republic
reply
. 2009-09-28 14:12:12.185 Using SFTP protocol.
. 2009-09-28 14:12:12.185 Doing startup conversation with host.
> 2009-09-28 14:12:12.185 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-09-28 14:12:12.185 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-09-28 14:12:12.185 SFTP version 3 negotiated.
. 2009-09-28 14:12:12.185 We believe the server has signed timestamps bug
. 2009-09-28 14:12:12.185 We will use UTF-8 strings for status messages only
. 2009-09-28 14:12:12.185 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-09-28 14:12:12.185 Getting current directory name.
. 2009-09-28 14:12:12.185 Getting real path for '.'
> 2009-09-28 14:12:12.185 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-09-28 14:12:12.185 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-09-28 14:12:12.185 Real path is '/root'
. 2009-09-28 14:12:12.185 Startup conversation with host finished.
. 2009-09-28 14:12:12.201 Cached directory change via "/tmp/" to "/tmp".
. 2009-09-28 14:12:12.201 Getting current directory name.
. 2009-09-28 14:12:12.201 Listing file "texto".
> 2009-09-28 14:12:12.201 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2009-09-28 14:12:12.201 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-09-28 14:12:12.201 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-09-28 14:12:12.201 Closing connection.
. 2009-09-28 14:12:12.201 Sending special code: 12
. 2009-09-28 14:12:12.201 Sent EOF message
. 2009-09-28 12:36:15.046 Using SFTP protocol.
. 2009-09-28 12:36:15.046 Doing startup conversation with host.
> 2009-09-28 12:36:15.046 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-09-28 12:36:15.061 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-09-28 12:36:15.061 SFTP version 3 negotiated.
. 2009-09-28 12:36:15.061 We believe the server has signed timestamps bug
. 2009-09-28 12:36:15.061 We will use UTF-8 strings for status messages only
. 2009-09-28 12:36:15.061 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-09-28 12:36:15.061 Getting current directory name.
. 2009-09-28 12:36:15.061 Getting real path for '.'
> 2009-09-28 12:36:15.061 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-09-28 12:36:15.061 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-09-28 12:36:15.061 Real path is '/root'
. 2009-09-28 12:36:15.061 Startup conversation with host finished.
. 2009-09-28 12:36:15.061 Listing file "/tmp/texto".
> 2009-09-28 12:36:15.061 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2009-09-28 12:36:15.061 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-09-28 12:36:15.061 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-09-28 12:36:15.061 Closing connection.
. 2009-09-28 12:36:15.061 Sending special code: 12
. 2009-09-28 12:36:15.061 Sent EOF message
. 2009-09-28 12:36:51.264 Using SFTP protocol.
. 2009-09-28 12:36:51.264 Doing startup conversation with host.
> 2009-09-28 12:36:51.264 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-09-28 12:36:51.279 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-09-28 12:36:51.279 SFTP version 3 negotiated.
. 2009-09-28 12:36:51.279 We believe the server has signed timestamps bug
. 2009-09-28 12:36:51.279 We will use UTF-8 strings for status messages only
. 2009-09-28 12:36:51.279 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-09-28 12:36:51.279 Getting current directory name.
. 2009-09-28 12:36:51.279 Getting real path for '.'
> 2009-09-28 12:36:51.279 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-09-28 12:36:51.279 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-09-28 12:36:51.279 Real path is '/root'
. 2009-09-28 12:36:51.279 Startup conversation with host finished.
. 2009-09-28 12:36:51.279 Listing file "/tmp/texto".
> 2009-09-28 12:36:51.279 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2009-09-28 12:36:51.279 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-09-28 12:36:51.279 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-09-28 12:36:51.279 Closing connection.
. 2009-09-28 12:36:51.279 Sending special code: 12
. 2009-09-28 12:36:51.279 Sent EOF message
. 2009-09-28 12:37:00.420 Using SFTP protocol.
. 2009-09-28 12:37:00.420 Doing startup conversation with host.
> 2009-09-28 12:37:00.420 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-09-28 12:37:00.420 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-09-28 12:37:00.420 SFTP version 3 negotiated.
. 2009-09-28 12:37:00.420 We believe the server has signed timestamps bug
. 2009-09-28 12:37:00.420 We will use UTF-8 strings for status messages only
. 2009-09-28 12:37:00.420 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-09-28 12:37:00.435 Getting current directory name.
. 2009-09-28 12:37:00.435 Getting real path for '.'
> 2009-09-28 12:37:00.435 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-09-28 12:37:00.435 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-09-28 12:37:00.435 Real path is '/root'
. 2009-09-28 12:37:00.435 Startup conversation with host finished.
. 2009-09-28 12:37:00.435 Listing file "/tmp/texto".
> 2009-09-28 12:37:00.435 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2009-09-28 12:37:00.435 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-09-28 12:37:00.435 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-09-28 12:37:00.435 Closing connection.
. 2009-09-28 12:37:00.435 Sending special code: 12
. 2009-09-28 12:37:00.435 Sent EOF message
. 2009-09-28 12:37:06.076 Using SFTP protocol.
. 2009-09-28 12:37:06.076 Doing startup conversation with host.
> 2009-09-28 12:37:06.076 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-09-28 12:37:06.092 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-09-28 12:37:06.092 SFTP version 3 negotiated.
. 2009-09-28 12:37:06.092 We believe the server has signed timestamps bug
. 2009-09-28 12:37:06.092 We will use UTF-8 strings for status messages only
. 2009-09-28 12:37:06.092 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-09-28 12:37:06.092 Getting current directory name.
. 2009-09-28 12:37:06.092 Getting real path for '.'
> 2009-09-28 12:37:06.092 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-09-28 12:37:06.092 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-09-28 12:37:06.092 Real path is '/root'
. 2009-09-28 12:37:06.092 Startup conversation with host finished.
. 2009-09-28 12:37:06.092 Listing file "/tmp/texto".
> 2009-09-28 12:37:06.092 Type: SSH_FXP_LSTAT, Size: 19, Number: 263
< 2009-09-28 12:37:06.092 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-09-28 12:37:06.092 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-09-28 12:37:06.092 Closing connection.
. 2009-09-28 12:37:06.092 Sending special code: 12
. 2009-09-28 12:37:06.092 Sent EOF message
. 2009-09-28 12:37:16.420 -------------------------
. 2009-09-28 12:37:16.685 Using SFTP protocol.
. 2009-09-28 12:37:16.685 Doing startup conversation with host.
> 2009-09-28 12:37:16.685 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-09-28 12:37:16.701 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-09-28 12:37:16.701 SFTP version 3 negotiated.
. 2009-09-28 12:37:16.701 We believe the server has signed timestamps bug
. 2009-09-28 12:37:16.701 We will use UTF-8 strings for status messages only
. 2009-09-28 12:37:16.701 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-09-28 12:37:16.701 Getting current directory name.
. 2009-09-28 12:37:16.701 Getting real path for '.'
> 2009-09-28 12:37:16.701 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-09-28 12:37:16.701 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-09-28 12:37:16.701 Real path is '/root'
. 2009-09-28 12:37:16.701 Startup conversation with host finished.
. 2009-09-28 12:37:16.701 Listing file "'/tmp/texto".
> 2009-09-28 12:37:16.701 Type: SSH_FXP_LSTAT, Size: 26, Number: 263
< 2009-09-28 12:37:16.701 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-09-28 12:37:16.701 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-09-28 12:37:16.701 Closing connection.
. 2009-09-28 12:37:16.701 Sending special code: 12
. 2009-09-28 12:37:16.701 Sent EOF message
pattyengr
Problem with Space
Hi I am using 5.0.7 version of WinSCP and when transferring file using the below commands through command prompt I am not able to send files with spaces. Well I am able to send the same file if I replace space with underscore
option batch abort
option conusername,server name password
cd (remote path)
lcd (local path)
option transfer binary
put File name with spaces
