Can not duplicate, move to, grep
nicedreams
I'm unable to duplicate a directory, or use the move to, or any of the commands like grep. When I right click to duplicate a directory, starts loading and the last thing I see in the box is starting the session...
Its SFTP-3. I'm using 4.1.9 build 416, commander interface, on windows vista ultimate 64. I tried the latest beta version, and that doesn't work either.
Re: Can not duplicate, move to, grep
nicedreams
Here you go. This is an example of using duplicate:
. 2009-09-21 10:32:33.902 [Shell] Looking up host "216
. 2009-09-21 10:32:33.902 [Shell] Connecting to 216
. 2009-09-21 10:32:33.969 [Shell] Server version: SSH-2.0-OpenSSH_5.1p1 Debian-5
. 2009-09-21 10:32:33.969 [Shell] We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2009-09-21 10:32:33.969 [Shell] SSPI: acquired credentials for: default@default-PC
. 2009-09-21 10:32:33.969 [Shell] Cannot convert IP address to SPN: DNS is not trusted
. 2009-09-21 10:32:34.000 [Shell] GSSKEX disabled: The operation completed successfully.
. 2009-09-21 10:32:34.000 [Shell] Using SSH protocol version 2
. 2009-09-21 10:32:34.000 [Shell] Doing Diffie-Hellman group exchange
. 2009-09-21 10:32:34.102 [Shell] Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-09-21 10:32:34.331 [Shell] Host key fingerprint is:
. 2009-09-21 10:32:34.331 [Shell] ssh-rsa 1024 68:17
. 2009-09-21 10:32:34.332 [Shell] Initialised AES-256 SDCTR client->server encryption
. 2009-09-21 10:32:34.332 [Shell] Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-09-21 10:32:34.332 [Shell] Initialised AES-256 SDCTR server->client encryption
. 2009-09-21 10:32:34.332 [Shell] Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-09-21 10:32:34.428 [Shell] Using username "nicedrea".
. 2009-09-21 10:32:34.500 [Shell] Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2009-09-21 10:32:34.500 [Shell] Using stored password.
. 2009-09-21 10:32:34.570 [Shell] Access granted
. 2009-09-21 10:32:34.598 [Shell] Opened channel for session
. 2009-09-21 10:32:34.627 [Shell] Started a shell/command
. 2009-09-21 10:32:34.629 [Shell] --------------------------------------------------------------------------
. 2009-09-21 10:32:34.629 [Shell] Using SCP protocol.
. 2009-09-21 10:32:34.629 [Shell] Doing startup conversation with host.
. 2009-09-21 10:32:34.632 [Shell] Skipping host startup message (if any).
> 2009-09-21 10:32:34.633 [Shell] echo "WinSCP: this is end-of-file:0"
< 2009-09-21 10:32:34.679 [Shell] nicedrea@nicedreams-2:~$ WinSCP: this is end-of-file:0
. 2009-09-21 10:32:34.679 [Shell] Detecting variable containing return code of last command.
. 2009-09-21 10:32:34.679 [Shell] Trying "$status".
> 2009-09-21 10:32:34.679 [Shell] echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2009-09-21 10:32:34.709 [Shell] nicedrea@nicedreams-2:~$
< 2009-09-21 10:32:34.709 [Shell] WinSCP: this is end-of-file:0
. 2009-09-21 10:32:34.709 [Shell] Trying "$?".
> 2009-09-21 10:32:34.709 [Shell] echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2009-09-21 10:32:34.805 [Shell] nicedrea@nicedreams-2:~$ 0
< 2009-09-21 10:32:34.805 [Shell] WinSCP: this is end-of-file:0
. 2009-09-21 10:32:34.805 [Shell] Getting current directory name.
> 2009-09-21 10:32:34.805 [Shell] pwd ; echo "WinSCP: this is end-of-file:0"
< 2009-09-21 10:32:34.901 [Shell] nicedrea@nicedreams-2:~$ /web/sites/nicedrea
< 2009-09-21 10:32:34.901 [Shell] WinSCP: this is end-of-file:0
. 2009-09-21 10:32:34.910 [Shell] Attempt to close connection due to fatal exception:
* 2009-09-21 10:32:34.910 [Shell] (EAbort) Operation aborted
. 2009-09-21 10:32:34.910 [Shell] Closing connection.
. 2009-09-21 10:32:34.910 [Shell] Sending special code: 12
. 2009-09-21 10:32:34.910 [Shell] Sent EOF message
