WinSCP strange error
TonyRuss
When attempting to change into a directory on the FTP server, WinSCP returns and error that direcotry 3134-01022_ XXXXX cant be found. The directory is actually called 3134-010229 XXXXX. For some reason, the 9 is being changed/interpreted as an _ character.
Any ideas?
Tony Russell
Re: WinSCP strange error
