Hide or minimize dos box when running scripts
Bob
I am using my first implemenation of WinScp. The scripts run great, but display a dos box over my calling program. Is there a way to hide the dos box or tell WinScp to run minimized?
Thanks for the help!
Re: Hide or minimize dos box when running scripts
Do you run winscp.exe or winscp.com? If winscp.exe, just avoid the /console parameter. If winscp.com, make sure you really need that one. If you really do, you need to emulate the console environment somehow. I do not remember anymore. Check MSDN then.
Your instructions worked great. Thank you.
-Bob
