Delete remote files, but not remote directories
oced
Greetings:
First, I'd like to say what a great program winscp is.
I've been tasked with automating the downloading of files from a remote server using a script. My requirements are:
    1. Download all files and directories from the remote host
    2. After downloading the files, I have to delete the remote files but NOT the remote directories.
    3. I won't know ahead of time the names of the files or directories so I can't put those into my script.
    4. My remote user id is a virtual user so I cannot use SSH to login after downloading and use standard Unix commands to delete the remote files.
I've been able to recursively download my test files and directories with no problem at all. When I add the -delete option to get, it deletes all of the directories and sub-directories too. More deleting than I want. My command is
get -preservetime -delete *.*
Any ideas about how I can delete the remote files but not the remote directories? Thanks.
Re: Delete remote files, but not remote directories
Do you ant to delete a contents of the directories? I.e. to keep just directory structure?
oced
Yes. That's it exactly: keep just the remote server's directory structure after I've downloaded the files.
Thanks.
I'm afraid there's no simple solution for this using WinSCP.
