Transferring many files via TLS/SSL fails
jusicgn
Cologne, Germany
when transferring a folder with many files and a bunch of subdirs via SSL or TLS to my server, I get the following error message after a while:
Error transferring file...
The server cannot open connection in active mode. If the problem persists, consider switching to passive mode.
Unable to build data connection: Operation not permitted
The connection is set to passive mode, so I think there must be a problem, that WinSCP causes to "forget" this...
When I transfer the same directory in FTP mode (without encryption) it works fine.
Any solution for this?
Greetz
JUSI
_________________
WinSCP 4.2.3 (Build 494), Win XP SP3
Re: Transferring many files via TLS/SSL fails
jusicgn
Cologne, Germany
Think I've got a little closer to the problem:
After having a closer look to the point where WinSCP throws the error, I figured out that it was when trying to upload a folder conataining two empty (0 KB) files.
However, this only comes up when using SSL/TLS.
With unencrypted FTP it works fine.
Any thoughts?
Greetz
JUSI
_________________
jusicgn
Cologne, Germany
Thanks a lot!
Looking forward to that.
Greetz
JUSI
_________________
