Unable to run winscp script from Java App
tmpuser
Unable to run winscp script from Java App code's process runtime.exec(cmd)
=> Application just hangs and does not execute the script.
(This same script runs from the command line successfully without error.)
I am using the latest WinSCP v4.2.3
cmd =
c:\program files\winscp3\winscp.com /script=scriptFile.txt /parameter \\path_to_remote_file\filename /log=logfile.xml
scriptFile.txt file =
option batch abort
open user:pswd@server
cd remote_path
option transfer binary
put -nopermissions %1%
close
I have also tried this command in the Java App without the path as:
winscp.com /script=scriptfile.txt /parameter \\path_to_remote_file /log=logfile.xml
(My System Env variable PATH includes c:\program files\winscp3\ )
==> still hangs Java App
I have also tried this command in the Java App using winscp.exe command instead:
c:\program files\winscp3\winscp.exe /console /script=scriptFile.txt /parameter \\path_to_remote_file\filename /log=logfile.xml
==> Java App runs the command but the Winscp GUI display as if no script was provided.
Any suggestions on getting this to work via the Java App?
Thanks,
cwgd
Re: Unable to run winscp script from Java App
cwgd
I have used logs on the command line with success but not from the Java App.
The WINSCP command is not working from the Java App and therefore no log is generated. It seems that only the command itself is recognized by the app and not the rest of the line of information including the script and logfile.
Has anyone else been able to run this tool from a Java App?
Thanks,
cwgd
BiBo
Sorry for rising up such old post, but just in case if somebody else face this problem (as I did)...
I've got WinSCP runnig with /script parameter from Java this way:
Runtime.getRuntime().exec("cmd /c <full WinSCP file name> /script=<script filename>");
If I haven't used "cmd /c" script wasn't executed.
May be it will help somebody.
