Renaming transferred file to remote server
urnrg
Hi. I came across an issue when I copy a file. If I want to rename a file but want to rename it from *.* to _*_.* (adding underscores in my case) the filename will be changed from foo.bar to _oo_.bar.
In fact, adding any number of characters at the beginning will simply replace the same number characters in the filename.
Is there a reason for this or did I find an anomaly?
Re: Renaming transferred file to remote server
Anonymous wrote:
No problems. Is there a reason for this convention?
That's how masks work on Windows. Try
copy somefile _*_
urnrg
copy somefile _*_
Not exactly the same
WinSCP: foo.bar _*_.* -> _oo_.bar
Windows: copy foo.bar _*_.* -> _oo.bar_
It's close, though, and I learnt something of Windows. Thanks.
