Script Logical Error
Anil
Hey,
I have Used the WInscp.exe to downaload the files from sftp and in order do that created a SSIS package and called the script file from the ssis package, Here the problem is with the file names and when ever I mentions complete file name then The file was downloading to the working directory but if I specifies *.* or *.csv then nothing was downloading from the file and on top of the getting error message......
open batch on
open confirm off
Open SFTP connection
Option transfer binary
cd direcotry
get *.csv path
close
error message:: No valid incoming packet found; Error listing 'directory'
Please correct me if i am doing some thing wrong.......
thanks,
-Anil.
Re: Script Logical Error
