True Symbolic Link Resolving
purefusion
Happyworld Land
I'd like to get WinSCP to go to the real link location, rather than appearing to have gone to a subdirectory named as the symbolic link.
For example, say I have a directory called 'app' and inside of that directory I have a symbolic link named 'theme-frontend' which points to 'theme/frontend/default/'
I'd like WinSCP to go to 'app/theme/frontend/default/' not simply 'app/theme-frontend/' ...especially in the path bar, because I like to be able to click on other directories like 'frontend/' and go there without having to first go back to 'app' then manually go to 'frontend/' using the commander/explorer folder tree interface.
So, how can this be done? I swear I've seen it happen before.
Re: True Symbolic Link Resolving
WinSCP does what the server tells it to do. So your problem is protocol specific. What protocol are you using?
purefusion wrote:
In this case, it's SCP (SSH) and I don't expect to stop using it. :)
With SCP WinSCP just does "cd subdirectory". It ends up where the remote server ends up after the command. With typical *nix server that would not be resolved to symlink target.
