Keep Connection Alive
I have a scanner that drops files into a folder throughout the day. I need to automatically upload these files to a server. I created this script to do that job, and a .bat file for my users to launch WinSCP.
But, how can I keep the connection alive, or reconnect every time a file is placed in the required folder?
Script:
Script:
# Automatically answer all prompts negatively not to stall # the script on errors (off), set to 'contunue' to ignore all errors. option batch off # Attempt reconnect in 3 seconds if connection fails option reconnecttime 3 # Disable overwrite confirmations that conflict with the previous option confirm off # Open connection to server open ftp://[server].com:[port#] # Synchronize directories so 'keepuptodate' won't cause problems. synchronize both "C:\Documents and Settings\user\Desktop\FTP_folder" # With the sync we can use 'uptodate' to keep the folders synced keepuptodate -delete "C:\Documents and Settings\user\Desktop\FTP_folder"
