OpenCandy crashed WinSCP installation
DfA
When trying to install latest WinSCP beta on a host accessing internet through user authenticated http proxy, the setup aborts with this kind of alert even if you gave the /nocandy parameter.
Error
Runtime Error (at -1:0):
Cannot Import dll:C:\DOCUME~1\<profiledir>\LOCALS~1\Temp\is-CNGTB.tmp\OCSetupHlp.dll.
OK
I don't want to complain here on your OpenCandy choice, but could you at least have the /nocandy option working as expected?
Thanks,
DfA
Re: OpenCandy crashed WinSCP installation
Are you using Windows 2000? If you are this is known bug.
Next release.
