Can't connect when I use my keys
Hartman
Hello All,
I have a bunch of linux server running debian and I just can't get WinSCP build 110 to connect via keys. When I allow password auth it works fine. Basiclly I point out the key and it keeps asking only for the password not the passphrase. It seem to only want to do passwords
Debian 3.0
OpenSSH_3.4p1 Debian 1:3.4p1-1
here are some logs.
Hartman
. WinSCP Version 2.0.0 (Build 110)
. Login time: Monday, January 06, 2003 5:11:48 PM
. Session name: ********
. Host name: ******* (Port: 22)
. User name: ******* (Password: No, Key file: Yes)
. SSH protocol version: 1; Compression: No
. Agent forwarding: No; TIS/CryptoCard authentication: No
. Imitate SSH2 MAC bug: No; Cipher: blowfish
. Ping interval: 0 min (0 = off)
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Server version: SSH-1.99-OpenSSH_3.4p1 Debian 1:3.4p1-1
. We claim version: SSH-1.5-PuTTY
. Using SSH protocol version 1
. Received public keys
. Host key fingerprint is:
. 1024 a7:4e:e4:59:a2:5b:68:e3:8c:e1:4c:87:8e:9a:dc:ab
. Encrypted session key
. Using Blowfish encryption
. Trying to enable encryption...
. Initialised Blowfish encryption
. Successfully started encryption
. Sent username "******"
! Couldn't load public key from H:\.ssh\id_rsa.pub.
. No more passwords to try
* (ESshFatal) Not connected!
. Login time: Monday, January 06, 2003 5:13:03 PM
. Sent username "hartman"
! Couldn't load public key from /home/hartman/.ssh/id_rsa.pub.
. Sent password
. Authentication refused
. Login time: Monday, January 06, 2003 5:14:05 PM
. Sent username "*******"
. Login time: Monday, January 06, 2003 5:14:43 PM
! Couldn't load public key from H:\.ssh\identity1.pub.
. Login time: Monday, January 06, 2003 5:15:20 PM
. Host name: gandalf.longfleet.com (Port: 22)
. Sent password
. Sent password
Re: Can't connect when I use my keys
As you may see in log, your key format is not supported by WinSCP. Either create new keys using keygen tool from Simon Tatham distributed in installation package or wait few more days for new release of WinSCP. It should support your key format.
Thanks prikryl,
Thanks I knew it was a problem with keys I just did not realize it was the way the key was formated.
Hartman
