[REQUEST]Make the font for the path bigger and more readable
kYuZz
I think it would be nice if the font for the path at top of each panel (in commander view) was bigger.
Also, the current color combination (black on blue) is not very readable.
Re: [REQUEST]Make the font for the path bigger and more readable
WinSCP should use the same colors as are used for Windows caption. So as long as your have sensible theme in Windows it should be readable. Can you post a screenshot?
kYuZz
<invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>)
Even if probably the readability of the color combo is arguable, I would like that the font was bigger.
