How to set 'Ignore permission errors' option in script?
Sanjay
I am getting the below error while uploading a file through scripting.
Upload of file 'test.txt' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option
Can someone help me on this? How can I use 'Ignore permission errors' in script?
Many thanks,
Re: How to set 'Ignore permission errors' option in script?
You should better turn off the option that actually causes the problem (-nopermissions or -nopreservetime).
See the documentation for the error:
Upload of file .. was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on ‘Ignore permission errors’ option.
For an answer to your literal question, please read How do I configure site, transfer and/or any other settings for which there are no script commands?
