Cannot script a connection!!
When I interactively use WinSCP to SFTP (with SCP fallback) to a SUSE host, it works fine. However when I try to do /console, I get:
winscp> open <host>
Searching for host...
Connecting to host...
Authenticating...
Username: <xxx>
Using keyboard-interactive authentication.
Password: <xxx>
Connection has been unexpectedly closed. Server sent command exist status 0.
Authentication failed.
winscp>
why does this happen? Passwords, everything is right.
Re: Cannot script a connection!!
