"option include" functionality
rclerkin
Ireland
I've been trying to figure out the option include and exclude features of winscp.
I've been having a conversation with myself over at this topic which describes what I've seen.
I believe the "option include" feature works in a counter intuitive way as it doesn't seem to include files and folders recurrsively.
i.e.
When you exclude a directory eveything within that directory is excluded
When you include a directory nothing within that directory is included
If I am correct with the above statements then I'd like to suggest that the include functionality be changed so that eveything within the included directory is also included
Re: "option include" functionality
Maybe it is not intuitive, but it is quite flexible. It allows both recursive and non-recursive inclusion.
rclerkin
Ireland
I see your point on the flexibility but maybe it would be better to specify if there should be recurrsion on the command line with a parameter to the "option include". Something like;
option include "<dir1>; <dir2>" R
for recurrsion or;
option include "<dir1>; <dir2>" NR
for No Recurrsion. The recurrsion parameter would be the default if nothing is specified.
I think this would make it more intuitive while keeping the flexibility.
This way you cannot make dir1 recursive and dir2 non-recursive. It is hard to find a syntax for this without breaking the backwards compatibility too much. For the same reason I cannot make recursive mode the default one.
