Unable to move files to USB Drive
Rilly
Using WinSCP (4.1.9 build 416) I am not able to move files to a new external USB drive from my remote linux server. I did read that system normally won't allow moves to different file systems, but both are formatted as ext3. I can perform the same move via commandline ssh (using mv). Using winscp, I'm able to duplicate the files to the USB drive.
If I can do it in ssh commandline, how come it won't work in WinSCP? I am logged in as root as well.
OS on the remote server is Debian 4.0. When I attempt, i get the error
Error code: 4
Error message from server: Failure
Request code: 18
From the logging:
. 2009-07-18 11:51:11.657 Moving file "The_Christmas_Raccoons.avi" to "/home/torrentflux/usb/The_Christmas_Raccoons.avi".
> 2009-07-18 11:51:11.657 Type: SSH_FXP_RENAME, Size: 133, Number: 10258
> 2009-07-18 11:51:11.657 12,00,00,28,12,00,00,00,48,2F,68,6F,6D,65,2F,74,6F,72,72,65,6E,74,66,6C,75,
> 2009-07-18 11:51:11.657 78,2F,6D,69,6F,64,75,64,65,2F,54,68,65,2E,52,61,63,63,6F,6F,6E,73,2E,5B,43,
> 2009-07-18 11:51:11.657 41,4B,4C,5D,2F,54,68,65,5F,43,68,72,69,73,74,6D,61,73,5F,52,61,63,63,6F,6F,
> 2009-07-18 11:51:11.657 6E,73,2E,61,76,69,00,00,00,30,2F,68,6F,6D,65,2F,74,6F,72,72,65,6E,74,66,6C,
> 2009-07-18 11:51:11.657 75,78,2F,75,73,62,2F,54,68,65,5F,43,68,72,69,73,74,6D,61,73,5F,52,61,63,63,
> 2009-07-18 11:51:11.657 6F,6F,6E,73,2E,61,76,69,
. 2009-07-18 11:51:11.657 Sent 137 bytes
. 2009-07-18 11:51:11.657 There are 0 bytes remaining in the send buffer
. 2009-07-18 11:51:11.657 Looking for network events
. 2009-07-18 11:51:11.657 Timeout waiting for network events
. 2009-07-18 11:51:11.657 Read 4 bytes (24 pending)
. 2009-07-18 11:51:11.657 Read 24 bytes (0 pending)
< 2009-07-18 11:51:11.657 Type: SSH_FXP_STATUS, Size: 24, Number: 9988
< 2009-07-18 11:51:11.657 65,00,00,27,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2009-07-18 11:51:11.657 Discarding reserved response
. 2009-07-18 11:51:11.657 Waiting for another 4 bytes
. 2009-07-18 11:51:11.657 Looking for incoming data
. 2009-07-18 11:51:11.782 Detected network event
. 2009-07-18 11:51:11.782 Enumerating network events for socket 524
. 2009-07-18 11:51:11.782 Enumerated 1 network events making 1 cumulative events for socket 524
. 2009-07-18 11:51:11.782 Handling network read event on socket 524 with error 0
. 2009-07-18 11:51:11.782 Received 28 bytes (0)
. 2009-07-18 11:51:11.782 Read 4 bytes (24 pending)
. 2009-07-18 11:51:11.782 Read 24 bytes (0 pending)
< 2009-07-18 11:51:11.782 Type: SSH_FXP_STATUS, Size: 24, Number: 10258
< 2009-07-18 11:51:11.782 65,00,00,28,12,00,00,00,04,00,00,00,07,46,61,69,6C,75,72,65,00,00,00,00,
< 2009-07-18 11:51:11.782 Status/error code: 4, Message: 10258, Server: Failure, Language:
. 2009-07-18 11:51:11.782 Asking user:
. 2009-07-18 11:51:11.782 Error moving file 'The_Christmas_Raccoons.avi' to '/home/torrentflux/usb/The_Christmas_Raccoons.avi'. ("General failure (server should provide error description).
. 2009-07-18 11:51:11.782 Error code: 4
. 2009-07-18 11:51:11.782 Error message from server: Failure
. 2009-07-18 11:51:11.782 Request code: 18")
Re: Unable to move files to USB Drive
It is not about file system type, but actual physical file system (read "drive").
Well, that's rather a question for those who implement the "mv" command and your SFTP server.
