Can WinSCP run a command on the local computer?
tibberous
PA
I just used PHP, mysql and WinSCP to make a great remote backup system for our server! Basically, a PHP file reads the site list from the server, writes out a WinSCP script and executes it.
The problem is that I want to be able to run a PHP command after every site. I could just have it write out many small files, but then it would open a new window every site. Is there a way to get WinSCP to run a command on the computer it is running on? Like a local version of call?
Re: Can WinSCP run a command on the local computer?
No. This request has been added to tracker.
Not necessarily. Make sure you use winscp.com.
