Upload limit at 4096
donkishoot
Nanterre
Hi developer,
I've tested all version of winscp and it seems that a bug has been introduce between winscp407.exe and winscp410.exe
With 4.07 i can upload (sftp) in an Axway XFB Gateway but after this release, all upload crash and restart in loop after 4096 and append with 4096 more and so on ...
Can i help you find the bug and how ?
I love your software and doesn't want to stay in an old release
:mrgreen:
Re: Upload limit at 4096
donkishoot
Nanterre
Log from with WinSCP 4.1.9 (no problem with 4.0.7)
. 2009-07-07 19:56:52.252 --------------------------------------------------------------------------
. 2009-07-07 19:56:52.252 WinSCP Version 4.1.9 (Build 416) (OS 5.1.2600 Service Pack 3)
. 2009-07-07 19:56:52.252 Login time: mardi 7 juillet 2009 19:56:52
. 2009-07-07 19:56:52.252 Session name: xxx.fr
. 2009-07-07 19:56:52.252 Host name: xxx.fr (Port: xx)
. 2009-07-07 19:56:52.252 User name: testrv (Password: Yes, Key file: No)
. 2009-07-07 19:56:52.252 Tunnel: No
. 2009-07-07 19:56:52.252 Transfer Protocol: SFTP (SCP)
. 2009-07-07 19:56:52.252 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-07-07 19:56:52.252 Proxy: none
. 2009-07-07 19:56:52.252 SSH protocol version: 2 only; Compression: Yes
. 2009-07-07 19:56:52.252 Bypass authentication: No
. 2009-07-07 19:56:52.252 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-07-07 19:56:52.252 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-07-07 19:56:52.252 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-07-07 19:56:52.252 SFTP Bugs: -,-
. 2009-07-07 19:56:52.252 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-07-07 19:56:52.252 Shell: default, EOL: 0
. 2009-07-07 19:56:52.252 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-07-07 19:56:52.252 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-07-07 19:56:52.252 Local directory: D:\Perso, Remote directory: /, Update: Yes, Cache: Yes
. 2009-07-07 19:56:52.252 Cache directory changes: Yes, Permanent: Yes
. 2009-07-07 19:56:52.252 DST mode: 1
. 2009-07-07 19:56:52.299 Looking up host "xxx.fr"
. 2009-07-07 19:56:52.299 Connecting to x.x.x.x port xx
. 2009-07-07 19:56:52.346 Selecting events 63 for socket 564
. 2009-07-07 19:56:52.346 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:52.346 Looking for incoming data
. 2009-07-07 19:56:52.346 Looking for network events
. 2009-07-07 19:56:52.346 Detected network event
. 2009-07-07 19:56:52.346 Enumerating network events for socket 564
. 2009-07-07 19:56:52.346 Enumerated 18 network events making 18 cumulative events for socket 564
. 2009-07-07 19:56:52.346 Handling network write event on socket 564 with error 0
. 2009-07-07 19:56:52.346 Handling network connect event on socket 564 with error 0
. 2009-07-07 19:56:52.424 Detected network event
. 2009-07-07 19:56:52.424 Enumerating network events for socket 564
. 2009-07-07 19:56:52.424 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:52.424 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:52.424 Server version: SSH-2.0-XFB.Gateway Unix
. 2009-07-07 19:56:52.424 We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2009-07-07 19:56:52.424 SSPI: acquired credentials for: x@x.LOC
. 2009-07-07 19:56:52.424 Constructed service principal name 'host/xxx.fr'
. 2009-07-07 19:56:52.674 GSSKEX disabled: La cible spécifiée est inconnue ou inaccessible
. 2009-07-07 19:56:52.674 Using SSH protocol version 2
. 2009-07-07 19:56:52.674 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:52.674 Looking for incoming data
. 2009-07-07 19:56:52.674 Looking for network events
. 2009-07-07 19:56:52.674 Detected network event
. 2009-07-07 19:56:52.674 Enumerating network events for socket 564
. 2009-07-07 19:56:52.674 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:52.674 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:52.674 Using Diffie-Hellman with standard group "group1"
. 2009-07-07 19:56:52.674 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-07-07 19:56:52.690 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:52.690 Looking for incoming data
. 2009-07-07 19:56:52.690 Looking for network events
. 2009-07-07 19:56:52.815 Detected network event
. 2009-07-07 19:56:52.815 Enumerating network events for socket 564
. 2009-07-07 19:56:52.815 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:52.815 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:52.846 Selecting events 63 for socket 564
. 2009-07-07 19:56:52.846 Host key fingerprint is:
. 2009-07-07 19:56:52.846 ssh-dss 1024 5e:94:c8:e1:5f:af:aa:70:69:0e:1c:f5:67:6f:a3:4d
. 2009-07-07 19:56:52.846 Initialised AES-128 CBC client->server encryption
. 2009-07-07 19:56:52.846 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-07-07 19:56:52.846 Initialised AES-128 CBC server->client encryption
. 2009-07-07 19:56:52.846 Initialised HMAC-SHA1 server->client MAC algorithm
. 2009-07-07 19:56:52.846 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:52.846 Looking for incoming data
. 2009-07-07 19:56:52.846 Looking for network events
. 2009-07-07 19:56:52.971 Detected network event
. 2009-07-07 19:56:52.971 Enumerating network events for socket 564
. 2009-07-07 19:56:52.971 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:52.971 Handling network read event on socket 564 with error 0
! 2009-07-07 19:56:52.971 Using username "testrv".
. 2009-07-07 19:56:52.971 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:52.971 Looking for incoming data
. 2009-07-07 19:56:52.971 Looking for network events
. 2009-07-07 19:56:53.018 Detected network event
. 2009-07-07 19:56:53.018 Enumerating network events for socket 564
. 2009-07-07 19:56:53.018 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.018 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.018 Prompt (6, SSH password, , &Password: )
. 2009-07-07 19:56:53.018 Using stored password.
. 2009-07-07 19:56:53.018 Sent password
. 2009-07-07 19:56:53.018 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:53.018 Looking for incoming data
. 2009-07-07 19:56:53.018 Looking for network events
. 2009-07-07 19:56:53.065 Detected network event
. 2009-07-07 19:56:53.065 Enumerating network events for socket 564
. 2009-07-07 19:56:53.065 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.065 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.065 Access granted
. 2009-07-07 19:56:53.065 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:53.065 Looking for incoming data
. 2009-07-07 19:56:53.065 Looking for network events
. 2009-07-07 19:56:53.112 Detected network event
. 2009-07-07 19:56:53.112 Enumerating network events for socket 564
. 2009-07-07 19:56:53.112 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.112 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.112 Opened channel for session
. 2009-07-07 19:56:53.112 Waiting for the server to continue with the initialisation
. 2009-07-07 19:56:53.112 Looking for incoming data
. 2009-07-07 19:56:53.112 Looking for network events
. 2009-07-07 19:56:53.158 Detected network event
. 2009-07-07 19:56:53.158 Enumerating network events for socket 564
. 2009-07-07 19:56:53.158 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.158 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.158 Started a shell/command
. 2009-07-07 19:56:53.158 --------------------------------------------------------------------------
. 2009-07-07 19:56:53.158 Using SFTP protocol.
. 2009-07-07 19:56:53.158 Doing startup conversation with host.
> 2009-07-07 19:56:53.158 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2009-07-07 19:56:53.158 01,00,00,00,05,
. 2009-07-07 19:56:53.158 Sent 9 bytes
. 2009-07-07 19:56:53.158 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.158 Looking for network events
. 2009-07-07 19:56:53.158 Timeout waiting for network events
. 2009-07-07 19:56:53.158 Waiting for another 4 bytes
. 2009-07-07 19:56:53.158 Looking for incoming data
. 2009-07-07 19:56:53.205 Detected network event
. 2009-07-07 19:56:53.205 Enumerating network events for socket 564
. 2009-07-07 19:56:53.205 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.205 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.205 Received 9 bytes (0)
. 2009-07-07 19:56:53.205 Read 4 bytes (5 pending)
. 2009-07-07 19:56:53.205 Read 5 bytes (0 pending)
< 2009-07-07 19:56:53.205 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2009-07-07 19:56:53.205 02,00,00,00,03,
. 2009-07-07 19:56:53.205 SFTP version 3 negotiated.
. 2009-07-07 19:56:53.205 We believe the server has signed timestamps bug
. 2009-07-07 19:56:53.205 We will use UTF-8 strings for status messages only
. 2009-07-07 19:56:53.205 Changing directory to "/".
. 2009-07-07 19:56:53.205 Getting real path for '/'
> 2009-07-07 19:56:53.205 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2009-07-07 19:56:53.205 10,00,00,00,10,00,00,00,01,2F,
. 2009-07-07 19:56:53.205 Sent 14 bytes
. 2009-07-07 19:56:53.205 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.205 Looking for network events
. 2009-07-07 19:56:53.205 Timeout waiting for network events
. 2009-07-07 19:56:53.205 Waiting for another 4 bytes
. 2009-07-07 19:56:53.205 Looking for incoming data
. 2009-07-07 19:56:53.252 Detected network event
. 2009-07-07 19:56:53.252 Enumerating network events for socket 564
. 2009-07-07 19:56:53.252 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.252 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.252 Received 102 bytes (0)
. 2009-07-07 19:56:53.252 Read 4 bytes (98 pending)
. 2009-07-07 19:56:53.252 Read 98 bytes (0 pending)
< 2009-07-07 19:56:53.252 Type: SSH_FXP_NAME, Size: 98, Number: 16
< 2009-07-07 19:56:53.252 68,00,00,00,10,00,00,00,01,00,00,00,01,2F,00,00,00,30,64,72,77,78,72,77,78,
< 2009-07-07 19:56:53.252 72,77,78,20,30,20,2D,2D,4E,41,2D,2D,20,2D,2D,4E,41,2D,2D,20,30,20,4A,75,6C,
< 2009-07-07 19:56:53.252 20,20,33,20,31,32,3A,35,30,20,74,65,73,74,72,76,00,00,00,0F,00,00,00,00,00,
< 2009-07-07 19:56:53.252 00,00,00,00,00,02,9A,00,00,02,9A,00,00,41,C0,4A,4D,E2,68,4A,4D,E2,68,
. 2009-07-07 19:56:53.252 Real path is '/'
. 2009-07-07 19:56:53.252 Trying to open directory "/".
> 2009-07-07 19:56:53.252 Type: SSH_FXP_LSTAT, Size: 10, Number: 263
> 2009-07-07 19:56:53.252 07,00,00,01,07,00,00,00,01,2F,
. 2009-07-07 19:56:53.252 Sent 14 bytes
. 2009-07-07 19:56:53.252 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.252 Looking for network events
. 2009-07-07 19:56:53.252 Timeout waiting for network events
. 2009-07-07 19:56:53.252 Waiting for another 4 bytes
. 2009-07-07 19:56:53.252 Looking for incoming data
. 2009-07-07 19:56:53.299 Detected network event
. 2009-07-07 19:56:53.299 Enumerating network events for socket 564
. 2009-07-07 19:56:53.299 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.299 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.299 Received 41 bytes (0)
. 2009-07-07 19:56:53.299 Read 4 bytes (37 pending)
. 2009-07-07 19:56:53.299 Read 37 bytes (0 pending)
< 2009-07-07 19:56:53.299 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
< 2009-07-07 19:56:53.299 69,00,00,01,07,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,02,9A,00,00,02,9A,
< 2009-07-07 19:56:53.299 00,00,40,00,00,00,00,00,00,00,00,00,
. 2009-07-07 19:56:53.299 Getting current directory name.
. 2009-07-07 19:56:53.299 Listing directory "/".
> 2009-07-07 19:56:53.299 Type: SSH_FXP_OPENDIR, Size: 10, Number: 523
> 2009-07-07 19:56:53.299 0B,00,00,02,0B,00,00,00,01,2F,
. 2009-07-07 19:56:53.299 Sent 14 bytes
. 2009-07-07 19:56:53.299 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.299 Looking for network events
. 2009-07-07 19:56:53.299 Timeout waiting for network events
. 2009-07-07 19:56:53.299 Waiting for another 4 bytes
. 2009-07-07 19:56:53.299 Looking for incoming data
. 2009-07-07 19:56:53.346 Detected network event
. 2009-07-07 19:56:53.346 Enumerating network events for socket 564
. 2009-07-07 19:56:53.346 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.346 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.346 Received 14 bytes (0)
. 2009-07-07 19:56:53.346 Read 4 bytes (10 pending)
. 2009-07-07 19:56:53.346 Read 10 bytes (0 pending)
< 2009-07-07 19:56:53.346 Type: SSH_FXP_HANDLE, Size: 10, Number: 523
< 2009-07-07 19:56:53.346 66,00,00,02,0B,00,00,00,01,30,
> 2009-07-07 19:56:53.346 Type: SSH_FXP_READDIR, Size: 10, Number: 780
> 2009-07-07 19:56:53.346 0C,00,00,03,0C,00,00,00,01,30,
. 2009-07-07 19:56:53.346 Sent 14 bytes
. 2009-07-07 19:56:53.346 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.346 Looking for network events
. 2009-07-07 19:56:53.346 Timeout waiting for network events
. 2009-07-07 19:56:53.346 Waiting for another 4 bytes
. 2009-07-07 19:56:53.346 Looking for incoming data
. 2009-07-07 19:56:53.393 Detected network event
. 2009-07-07 19:56:53.393 Enumerating network events for socket 564
. 2009-07-07 19:56:53.393 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.393 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.393 Received 34 bytes (0)
. 2009-07-07 19:56:53.393 Read 4 bytes (30 pending)
. 2009-07-07 19:56:53.393 Read 30 bytes (0 pending)
< 2009-07-07 19:56:53.393 Type: SSH_FXP_STATUS, Size: 30, Number: 780
< 2009-07-07 19:56:53.393 65,00,00,03,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2009-07-07 19:56:53.393 00,00,02,65,6E,
< 2009-07-07 19:56:53.393 Status/error code: 1
. 2009-07-07 19:56:53.393 Listing file "/..".
> 2009-07-07 19:56:53.393 Type: SSH_FXP_LSTAT, Size: 12, Number: 1031
> 2009-07-07 19:56:53.393 07,00,00,04,07,00,00,00,03,2F,2E,2E,
. 2009-07-07 19:56:53.393 Sent 16 bytes
. 2009-07-07 19:56:53.393 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.393 Looking for network events
. 2009-07-07 19:56:53.393 Timeout waiting for network events
. 2009-07-07 19:56:53.393 Waiting for another 4 bytes
. 2009-07-07 19:56:53.393 Looking for incoming data
. 2009-07-07 19:56:53.440 Detected network event
. 2009-07-07 19:56:53.440 Enumerating network events for socket 564
. 2009-07-07 19:56:53.440 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:53.440 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:53.440 Received 41 bytes (0)
. 2009-07-07 19:56:53.440 Read 4 bytes (37 pending)
. 2009-07-07 19:56:53.440 Read 37 bytes (0 pending)
< 2009-07-07 19:56:53.440 Type: SSH_FXP_ATTRS, Size: 37, Number: 1031
< 2009-07-07 19:56:53.440 69,00,00,04,07,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,02,9A,00,00,02,9A,
< 2009-07-07 19:56:53.440 00,00,40,00,00,00,00,00,00,00,00,00,
> 2009-07-07 19:56:53.440 Type: SSH_FXP_CLOSE, Size: 10, Number: 1284
> 2009-07-07 19:56:53.440 04,00,00,05,04,00,00,00,01,30,
. 2009-07-07 19:56:53.440 Sent 14 bytes
. 2009-07-07 19:56:53.440 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:53.440 Looking for network events
. 2009-07-07 19:56:53.440 Timeout waiting for network events
. 2009-07-07 19:56:53.440 Startup conversation with host finished.
. 2009-07-07 19:56:54.080 Session upkeep
. 2009-07-07 19:56:54.080 Looking for network events
. 2009-07-07 19:56:54.080 Detected network event
. 2009-07-07 19:56:54.080 Enumerating network events for socket 564
. 2009-07-07 19:56:54.080 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:54.080 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:54.080 Received 30 bytes (0)
. 2009-07-07 19:56:54.580 Session upkeep
. 2009-07-07 19:56:54.580 Looking for network events
. 2009-07-07 19:56:54.580 Timeout waiting for network events
. 2009-07-07 19:56:55.080 Session upkeep
. 2009-07-07 19:56:55.080 Looking for network events
. 2009-07-07 19:56:55.080 Timeout waiting for network events
. 2009-07-07 19:56:55.580 Session upkeep
. 2009-07-07 19:56:55.580 Looking for network events
. 2009-07-07 19:56:55.580 Timeout waiting for network events
. 2009-07-07 19:56:56.080 Session upkeep
. 2009-07-07 19:56:56.080 Looking for network events
. 2009-07-07 19:56:56.080 Timeout waiting for network events
. 2009-07-07 19:56:56.580 Session upkeep
. 2009-07-07 19:56:56.580 Looking for network events
. 2009-07-07 19:56:56.580 Timeout waiting for network events
. 2009-07-07 19:56:57.080 Session upkeep
. 2009-07-07 19:56:57.080 Looking for network events
. 2009-07-07 19:56:57.080 Timeout waiting for network events
. 2009-07-07 19:56:57.580 Session upkeep
. 2009-07-07 19:56:57.580 Looking for network events
. 2009-07-07 19:56:57.580 Timeout waiting for network events
. 2009-07-07 19:56:58.096 Session upkeep
. 2009-07-07 19:56:58.096 Looking for network events
. 2009-07-07 19:56:58.096 Timeout waiting for network events
. 2009-07-07 19:56:58.096 Copying 1 files/directories to remote directory "/"
. 2009-07-07 19:56:58.096   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2009-07-07 19:56:58.096   TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-07-07 19:56:58.096   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-07-07 19:56:58.096 File: "D:\Perso\horaires_sncf_2009.pdf"
. 2009-07-07 19:56:58.096 Copying "D:\Perso\horaires_sncf_2009.pdf" to remote directory started.
. 2009-07-07 19:56:58.096 Binary transfer mode selected.
. 2009-07-07 19:56:58.096 Checking existence of file.
> 2009-07-07 19:56:58.096 Type: SSH_FXP_LSTAT, Size: 32, Number: 1543
> 2009-07-07 19:56:58.096 07,00,00,06,07,00,00,00,17,2F,68,6F,72,61,69,72,65,73,5F,73,6E,63,66,5F,32,
> 2009-07-07 19:56:58.096 30,30,39,2E,70,64,66,
. 2009-07-07 19:56:58.096 Sent 36 bytes
. 2009-07-07 19:56:58.096 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:58.096 Read 4 bytes (26 pending)
. 2009-07-07 19:56:58.096 Read 26 bytes (0 pending)
< 2009-07-07 19:56:58.096 Type: SSH_FXP_STATUS, Size: 26, Number: 1284
< 2009-07-07 19:56:58.096 65,00,00,05,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,02,65,
< 2009-07-07 19:56:58.096 6E,
. 2009-07-07 19:56:58.096 Discarding reserved response
. 2009-07-07 19:56:58.096 Waiting for another 4 bytes
. 2009-07-07 19:56:58.096 Looking for incoming data
. 2009-07-07 19:56:58.143 Detected network event
. 2009-07-07 19:56:58.143 Enumerating network events for socket 564
. 2009-07-07 19:56:58.143 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:58.143 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:58.143 Received 35 bytes (0)
. 2009-07-07 19:56:58.143 Read 4 bytes (31 pending)
. 2009-07-07 19:56:58.143 Read 31 bytes (0 pending)
< 2009-07-07 19:56:58.143 Type: SSH_FXP_STATUS, Size: 31, Number: 1543
< 2009-07-07 19:56:58.143 65,00,00,06,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2009-07-07 19:56:58.143 00,00,00,02,65,6E,
< 2009-07-07 19:56:58.143 Status/error code: 2
. 2009-07-07 19:56:58.143 Checking existence of partially transfered file.
> 2009-07-07 19:56:58.143 Type: SSH_FXP_LSTAT, Size: 41, Number: 1799
> 2009-07-07 19:56:58.143 07,00,00,07,07,00,00,00,20,2F,68,6F,72,61,69,72,65,73,5F,73,6E,63,66,5F,32,
> 2009-07-07 19:56:58.143 30,30,39,2E,70,64,66,2E,66,69,6C,65,70,61,72,74,
. 2009-07-07 19:56:58.143 Sent 45 bytes
. 2009-07-07 19:56:58.143 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:58.143 Looking for network events
. 2009-07-07 19:56:58.143 Timeout waiting for network events
. 2009-07-07 19:56:58.143 Waiting for another 4 bytes
. 2009-07-07 19:56:58.143 Looking for incoming data
. 2009-07-07 19:56:58.190 Detected network event
. 2009-07-07 19:56:58.190 Enumerating network events for socket 564
. 2009-07-07 19:56:58.190 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:58.190 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:58.190 Received 35 bytes (0)
. 2009-07-07 19:56:58.190 Read 4 bytes (31 pending)
. 2009-07-07 19:56:58.190 Read 31 bytes (0 pending)
< 2009-07-07 19:56:58.190 Type: SSH_FXP_STATUS, Size: 31, Number: 1799
< 2009-07-07 19:56:58.190 65,00,00,07,07,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2009-07-07 19:56:58.190 00,00,00,02,65,6E,
< 2009-07-07 19:56:58.190 Status/error code: 2
. 2009-07-07 19:56:58.190 Opening remote file.
> 2009-07-07 19:56:58.190 Type: SSH_FXP_OPEN, Size: 57, Number: 2051
> 2009-07-07 19:56:58.190 03,00,00,08,03,00,00,00,20,2F,68,6F,72,61,69,72,65,73,5F,73,6E,63,66,5F,32,
> 2009-07-07 19:56:58.190 30,30,39,2E,70,64,66,2E,66,69,6C,65,70,61,72,74,00,00,00,1A,00,00,00,01,00,
> 2009-07-07 19:56:58.190 00,00,00,00,01,AB,9D,
. 2009-07-07 19:56:58.190 Sent 61 bytes
. 2009-07-07 19:56:58.190 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:58.190 Looking for network events
. 2009-07-07 19:56:58.190 Timeout waiting for network events
. 2009-07-07 19:56:58.190 Waiting for another 4 bytes
. 2009-07-07 19:56:58.190 Looking for incoming data
. 2009-07-07 19:56:58.252 Detected network event
. 2009-07-07 19:56:58.252 Enumerating network events for socket 564
. 2009-07-07 19:56:58.252 Enumerated 1 network events making 1 cumulative events for socket 564
. 2009-07-07 19:56:58.252 Handling network read event on socket 564 with error 0
. 2009-07-07 19:56:58.252 Received 14 bytes (0)
. 2009-07-07 19:56:58.252 Read 4 bytes (10 pending)
. 2009-07-07 19:56:58.252 Read 10 bytes (0 pending)
< 2009-07-07 19:56:58.252 Type: SSH_FXP_HANDLE, Size: 10, Number: 2051
< 2009-07-07 19:56:58.252 66,00,00,08,03,00,00,00,01,30,
> 2009-07-07 19:56:58.252 Type: SSH_FXP_WRITE, Size: 4118, Number: 2566
> 2009-07-07 19:56:58.252 06,00,00,0A,06,00,00,00,01,30,00,00,00,00,00,00,00,00,00,00,10,00,25,50,44,
> 2009-07-07 19:56:58.252 46,2D,31,2E,33,0A,25,AA,AB,AC,AD,0A,34,20,30,20,6F,62,6A,0A,3C,3C,20,2F,54,
> 2009-07-07 19:56:58.252 79,70,65,20,2F,49,6E,66,6F,0A,2F,50,72,6F,64,75,63,65,72,20,28,46,4F,50,20,
> 2009-07-07 19:56:58.252 30,2E,32,30,2E,35,29,20,3E,3E,0A,65,6E,64,6F,62,6A,0A,35,20,30,20,6F,62,6A,
> 2009-07-07 19:56:58.252 0A,3C,3C,20,2F,4C,65,6E,67,74,68,20,31,35,30,35,32,20,2F,46,69,6C,74,65,72,
> 2009-07-07 19:56:58.252 20,5B,20,2F,41,53,43,49,49,38,35,44,65,63,6F,64,65,20,2F,46,6C,61,74,65,44,
> 2009-07-07 19:56:58.252 65,63,6F,64,65,20,5D,0A,20,3E,3E,0A,73,74,72,65,61,6D,0A,47,62,21,24,4C,63,
> 2009-07-07 19:56:58.252 60,5A,3C,3C,52,63,4F,35,39,27,5E,23,59,42,3D,2B,3B,59,2A,42,5C,5A,23,59,45,
> 2009-07-07 19:56:58.252 75,55,4D,26,31,68,6E,74,3A,37,3A,6F,53,34,59,40,5D,4E,66,72,65,68,40,3F,50,
> 2009-07-07 19:56:58.252 2A,54,74,3C,4E,5F,66,6B,30,37,2C,72,43,46,61,75,57,2A,60,4B,49,48,27,75,49,
> 2009-07-07 19:56:58.252 6A,34,52,53,4A,2C,53,6E,25,72,71,62,5B,54,72,52,22,6D,34,54,6C,39,68,33,6B,
> 2009-07-07 19:56:58.252 2D,44,41,6D,65,3A,22,60,33,3F,69,55,28,33,3F,55,6F,56,44,54,44,6F,4E,27,5C,
> 2009-07-07 19:56:58.252 47,37,26,30,6E,5E,3A,2E,6C,66,30,24,47,2B,5E,5C,70,30,37,6C,69,37,22,52,54,
> 2009-07-07 19:56:58.252 33,70,4C,55,70,67,38,4F,4B,5D,3B,73,3E,5E,5E,46,57,67,46,6C,39,47,39,75,4C,
> 2009-07-07 19:56:58.252 39,45,36,2F,69,61,39,49,27,5E,5D,32,6F,48,35,46,53,65,55,71,50,34,22,28,66,
> 2009-07-07 19:56:58.252 29,4B,4F,23,67,3A,21,27,25,39,5D,3D,46,6C,6A,34,40,5A,3C,70,5A,6D,3E,2F,3E,
> 2009-07-07 19:56:58.252 4C,50,44,72,71,41,4B,3E,2F,6F,6B,33,2F,4F,53,61,66,4C,6E,71,44,35,36,3C,6F,
> 2009-07-07 19:56:58.252 44,35,65,70,35,4D,74,25,61,6E,2A,2F,2F,49,55,64,2B,61,27,72,56,37,3F,32,67,
> 2009-07-07 19:56:58.252 48,57,49,50,63,64,75,50,28,46,2A,23,6C,3C,34,38,62,2E,28,3B,4A,30,4B,68,3C,
> 2009-07-07 19:56:58.252 53,59,6B,75,3C,38,39,42,55,30,73,23,74,2E,31,52,6D,35,2B,4F,69,29,44,5D,56,
> 2009-07-07 19:56:58.252 72,5E,5C,37,70,64,57,68,71,3C,49,44,37,61,38,55,4D,3C,49,43,5D,43,3B,4C,27,
> 2009-07-07 19:56:58.252 37,5D,63,45,3A,59,4B,2A,34,70,56,35,49,5A,47,35,70,45,4A,2C,51,3C,26,45,44,
> 2009-07-07 19:56:58.252 68,24,3E,5D,47,43,42,47,46,72,64,48,70,4B,72,56,5E,6F,70,70,25,25,4C,4C,51,
> 2009-07-07 19:56:58.252 68,37,33,43,50,68,21,62,31,38,33,5D,31,41,63,66,23,40,2E,25,26,72,51,71,67,
> 2009-07-07 19:56:58.252 25,4D,5C,5D,35,4E,68,33,3F,5F,67,53,69,46,3F,59,5B,4A,69,44,23,2C,2C,66,5D,
> 2009-07-07 19:56:58.252 2A,3F,72,6B,36,2B,30,59,31,70,5B,6D,71,45,4A,2C,60,28,3E,2A,65,34,30,3C,46,
> 2009-07-07 19:56:58.252 2A,72,63,31,70,6C,3C,50,6A,6E,40,22,42,25,56,51,56,39,56,61,23,4B,49,2C,46,
> 2009-07-07 19:56:58.252 5D,38,6D,68,65,41,51,69,6B,41,53,42,50,53,49,6C,52,2F,26,54,73,34,4F,40,51,
> 2009-07-07 19:56:58.252 63,44,3A,25,33,36,73,26,52,6A,6D,4D,24,4B,47,59,23,6B,2D,72,56,6A,2F,24,6C,
> 2009-07-07 19:56:58.252 66,6C,6F,3B,21,44,5F,37,5D,72,62,22,31,5F,37,6A,6D,4F,3F,68,3C,54,50,71,73,
> 2009-07-07 19:56:58.252 26,33,60,47,39,74,4F,5D,57,53,4C,4F,51,54,71,46,3E,3C,47,5E,58,2C,49,4C,39,
> 2009-07-07 19:56:58.252 57,62,42,64,46,2E,41,21,50,6D,6B,3A,24,3C,24,57,4A,58,5D,70,4E,63,56,5E,62,
> 2009-07-07 19:56:58.252 6C,33,22,45,3F,50,6E,4F,6E,31,33,45,2D,61,47,44,46,3F,71,25,56,39,4A,3B,36,
> 2009-07-07 19:56:58.252 28,3A,5A,59,6E,2C,22,34,6C,57,39,4F,27,28,46,51,24,31,53,4F,3D,2D,5D,68,49,
> 2009-07-07 19:56:58.252 65,68,62,2D,32,45,6F,60,4E,43,44,56,60,27,54,5E,6A,73,4A,5F,75,67,6E,72,37,
> 2009-07-07 19:56:58.252 6D,4D,6B,64,54,55,3F,3F,54,32,63,44,49,4B,2D,3C,43,43,5B,45,62,27,5D,56,23,
> 2009-07-07 19:56:58.252 46,5C,65,41,2C,28,6A,54,4B,41,5B,28,23,21,24,6C,4C,32,49,35,3C,25,26,6E,5F,
> 2009-07-07 19:56:58.252 5D,2D,6D,6F,43,4B,61,58,40,3F,2E,54,75,4D,4A,41,5F,51,37,58,4D,5A,22,27,54,
> 2009-07-07 19:56:58.252 55,54,34,29,58,49,21,3C,5E,23,29,49,4D,73,52,3C,3C,61,59,52,4D,64,2D,3B,34,
> 2009-07-07 19:56:58.252 43,5C,2F,30,5C,44,6B,50,4F,6D,53,28,5B,2F,44,60,55,35,69,4F,45,64,46,64,46,
> 2009-07-07 19:56:58.252 68,23,3A,2B,6F,5A,63,43,3C,54,4E,60,42,52,2B,51,40,72,61,60,66,5C,3F,38,26,
> 2009-07-07 19:56:58.252 24,3F,3E,5C,69,35,62,6D,31,25,6C,3F,27,45,46,5D,48,4F,2B,6F,57,41,55,37,37,
> 2009-07-07 19:56:58.252 6F,39,50,4B,73,34,6B,69,46,21,32,57,57,39,3F,75,61,5F,46,36,67,4C,5D,4A,2B,
> 2009-07-07 19:56:58.252 52,71,5D,51,34,5D,31,71,5F,58,66,4C,6B,2F,48,3A,51,63,72,4D,24,4B,49,55,37,
> 2009-07-07 19:56:58.252 2C,39,64,31,59,2E,41,4E,57,4E,6B,2C,60,36,25,6C,43,55,28,46,6C,2B,6D,60,6C,
> 2009-07-07 19:56:58.252 46,70,5C,48,65,3A,21,47,52,63,63,71,44,23,3B,3E,31,4E,58,58,36,70,70,32,38,
> 2009-07-07 19:56:58.252 29,34,45,2C,23,46,5A,4E,5C,3B,43,63,42,36,47,2C,24,52,3F,5F,2C,32,52,48,69,
> 2009-07-07 19:56:58.252 64,6B,5C,67,39,3B,73,64,44,4E,6B,33,4F,5F,42,21,49,52,71,6A,35,52,23,74,39,
> 2009-07-07 19:56:58.252 4F,5E,3D,59,65,38,5F,31,25,65,54,25,3A,28,65,38,5E,52,70,54,55,43,71,40,6A,
> 2009-07-07 19:56:58.252 24,4E,34,37,6A,32,31,23,59,69,75,6D,6B,57,31,44,3C,58,2B,4C,23,41,75,6B,5F,
> 2009-07-07 19:56:58.252 58,2B,35,5D,2B,52,75,28,6E,52,32,56,66,5B,24,61,5A,6D,6F,52,69,34,64,3B,23,
> 2009-07-07 19:56:58.252 44,69,5C,53,6C,25,71,48,3D,43,30,62,75,3B,65,32,75,71,54,38,33,47,36,6D,2B,
> 2009-07-07 19:56:58.252 52,36,49,4E,45,37,4A,72,2C,45,37,41,6C,68,47,62,43,49,6D,57,38,6A,63,35,57,
> 2009-07-07 19:56:58.252 6F,47,6B,51,42,74,4D,51,6F,62,64,6C,3E,46,33,58,4B,65,54,4F,28,4C,2E,51,47,
> 2009-07-07 19:56:58.252 68,3A,2E,4B,4E,4E,42,24,57,41,34,55,50,67,5F,72,5F,54,6E,30,37,35,35,68,6C,
> 2009-07-07 19:56:58.252 26,4F,5B,26,4F,51,73,29,4E,3C,3F,70,3C,33,31,5C,64,27,73,42,69,5C,34,59,68,
> 2009-07-07 19:56:58.252 25,3D,5F,72,4D,21,44,2C,5C,37,46,62,34,59,60,25,33,70,45,33,5C,6B,2F,3D,32,
> 2009-07-07 19:56:58.252 3A,3C,4C,22,25,68,3E,52,46,39,3D,33,71,54,46,46,35,4D,5C,5E,39,3E,6E,6B,5C,
> 2009-07-07 19:56:58.252 39,4F,66,4E,40,4B,49,4A,5D,35,36,69,6F,60,57,26,6E,4A,32,29,2C,5D,35,21,5D,
> 2009-07-07 19:56:58.252 72,45,22,38,4E,67,4D,29,48,3C,22,46,74,67,29,58,33,39,4C,65,71,49,28,59,38,
> 2009-07-07 19:56:58.252 51,43,61,6C,37,6E,67,69,66,57,59,62,3D,44,24,24,41,61,33,53,4B,62,28,68,3A,
> 2009-07-07 19:56:58.252 3B,27,28,5F,68,25,3E,6A,41,4F,51,6F,2D,46,37,37,2C,66,42,65,21,23,6D,59,38,
> 2009-07-07 19:56:58.252 5C,49,50,5A,68,25,3A,3C,58,4D,21,44,36,42,44,69,6D,6B,3F,60,22,58,3E,69,5C,
> 2009-07-07 19:56:58.252 6D,26,2E,61,38,39,5F,75,74,2B,2F,46,34,21,34,3F,25,47,5E,3D,28,34,26,75,26,
> 2009-07-07 19:56:58.252 6A,4B,29,3B,6E,4F,54,6B,25,31,60,52,5D,27,5B,2D,46,31,70,6C,41,68,35,6B,4B,
> 2009-07-07 19:56:58.252 32,68,55,31,53,4A,28,34,4A,52,2D,4B,39,26,23,50,43,67,75,46,5B,6F,2C,23,36,
> 2009-07-07 19:56:58.252 29,6B,61,6F,3A,27,6C,26,35,39,49,44,21,60,56,63,4C,4B,30,36,4A,57,34,65,35,
> 2009-07-07 19:56:58.252 60,6B,37,73,5D,69,2E,38,52,26,62,41,5F,59,6C,3A,4A,5A,66,6B,27,3C,69,24,5E,
> 2009-07-07 19:56:58.252 43,34,43,6C,3C,63,6A,60,50,71,45,3A,3A,68,27,30,6B,72,53,5C,5C,30,31,4E,3F,
> 2009-07-07 19:56:58.252 67,66,2F,5F,47,6A,31,5C,6D,5C,3B,2A,3E,5F,27,28,5C,3E,4C,70,69,59,29,34,60,
> 2009-07-07 19:56:58.252 24,3B,72,2E,64,6D,30,23,69,43,26,52,2D,3E,34,4B,30,75,2C,2A,56,65,3B,38,39,
> 2009-07-07 19:56:58.252 6D,72,45,3E,36,49,60,31,67,3A,24,53,45,69,4D,2E,6E,2C,28,49,40,4F,38,5C,24,
> 2009-07-07 19:56:58.252 6C,6C,33,49,40,54,72,21,29,42,56,6E,4A,74,35,5A,2C,68,2F,42,63,6F,5B,73,27,
> 2009-07-07 19:56:58.252 25,39,25,23,71,53,26,40,5B,21,73,2E,5C,50,52,2F,4D,54,53,70,4F,63,25,22,64,
> 2009-07-07 19:56:58.252 4F,52,24,59,22,47,6D,59,6B,38,4E,62,45,4F,30,63,27,74,4C,54,2C,35,74,4C,4C,
> 2009-07-07 19:56:58.252 55,6E,65,6F,4B,46,6D,66,44,43,56,22,40,4C,5D,62,34,37,32,4F,53,48,59,37,67,
> 2009-07-07 19:56:58.252 50,21,2D,61,56,4D,48,41,66,40,35,31,33,33,6F,4C,64,3D,41,36,2F,69,5E,30,3E,
> 2009-07-07 19:56:58.252 6E,63,4C,67,51,6E,55,6B,46,37,6A,64,55,40,32,63,2E,21,25,4E,37,25,2B,41,62,
> 2009-07-07 19:56:58.252 5B,53,2C,34,52,40,35,52,27,34,33,33,4E,6E,4E,54,69,3E,2C,6F,68,2A,48,74,35,
> 2009-07-07 19:56:58.252 69,52,2E,3E,44,25,50,75,74,52,2D,39,2B,3E,4F,2F,40,5C,26,57,29,6D,48,42,23,
> 2009-07-07 19:56:58.252 38,30,36,2B,64,66,66,64,3B,51,43,2E,44,34,65,35,2A,34,34,32,40,2B,46,75,62,
> 2009-07-07 19:56:58.252 6C,39,72,6E,48,64,63,67,43,6C,42,52,60,5A,4B,23,45,47,64,27,52,63,45,75,29,
> 2009-07-07 19:56:58.252 57,4C,41,63,26,43,2D,30,5A,64,6D,65,38,46,5C,51,62,5A,5E,3F,55,3E,6A,63,68,
> 2009-07-07 19:56:58.252 64,3D,52,42,30,26,2F,24,53,63,5B,2C,5E,45,5C,2A,59,58,28,72,58,41,39,4F,46,
> 2009-07-07 19:56:58.252 5B,2D,36,73,51,31,56,4D,51,67,50,5C,74,71,2B,5F,75,67,26,32,70,46,56,36,3E,
> 2009-07-07 19:56:58.252 63,46,61,50,2A,22,6F,2C,70,43,66,4A,71,55,47,50,4B,72,2A,56,4C,22,5C,31,65,
> 2009-07-07 19:56:58.252 4F,58,6F,5A,53,2E,56,52,2E,3E,4F,29,41,63,32,3A,4E,58,31,3D,62,4E,62,5C,24,
> 2009-07-07 19:56:58.252 4E,6A,36,60,64,4E,28,4E,4E,4B,57,2F,39,2E,21,60,3A,69,27,2A,42,6F,6D,45,57,
> 2009-07-07 19:56:58.252 4C,63,55,57,32,3A,4E,58,31,4D,5A,67,23,3E,52,67,59,28,51,4F,6D,5F,60,27,2C,
> 2009-07-07 19:56:58.252 3E,40,63,56,5B,31,75,5B,64,68,3B,52,72,70,52,2D,4F,3F,5A,2F,23,6C,28,4D,5F,
> 2009-07-07 19:56:58.252 72,6C,71,33,65,56,65,60,6C,4B,59,23,26,4B,4D,42,4C,47,3A,56,71,72,41,64,6D,
> 2009-07-07 19:56:58.252 64,4C,4E,2C,39,5F,47,28,38,29,6B,6C,5D,68,52,33,3E,38,73,55,75,21,26,61,6D,
> 2009-07-07 19:56:58.252 64,4D,59,4B,38,47,31,57,36,70,49,3B,29,43,48,6E,23,44,23,68,35,55,2D,3C,57,
> 2009-07-07 19:56:58.252 26,6F,43,4C,23,5A,45,6D,64,70,49,3B,29,43,48,74,69,73,64,34,66,65,3C,48,57,
> 2009-07-07 19:56:58.252 26,6F,42,25,23,75,56,63,5E,70,22,66,73,73,4C,4A,4B,37,2A,57,64,46,45,71,23,
> 2009-07-07 19:56:58.252 5E,28,70,4B,2C,25,37,4C,28,48,3E,65,4A,4A,5F,65,35,23,61,65,56,65,60,6C,4B,
> 2009-07-07 19:56:58.252 59,23,27,36,4E,3F,48,62,4D,58,35,34,65,68,6D,64,54,48,62,39,5F,47,28,38,29,
> 2009-07-07 19:56:58.252 6B,6C,5D,68,66,64,54,56,66,55,75,21,27,5E,58,4F,4B,40,3B,5D,27,36,3C,59,31,
> 2009-07-07 19:56:58.252 29,39,47,59,51,2E,6E,63,73,51,61,67,5B,3B,4C,6F,56,51,66,41,43,50,61,53,62,
> 2009-07-07 19:56:58.252 30,4F,3A,42,6E,6C,26,4A,55,58,23,73,44,53,34,31,28,2E,75,4A,3A,3C,38,53,6F,
> 2009-07-07 19:56:58.252 21,41,6D,47,5B,2C,59,6F,35,46,72,32,38,32,70,72,71,26,2D,38,57,71,38,65,63,
> 2009-07-07 19:56:58.252 4C,39,2B,50,53,75,4D,4E,2B,3E,30,36,40,68,5E,48,6A,41,5D,3C,6F,6E,4F,3D,2D,
> 2009-07-07 19:56:58.252 2D,71,6B,53,25,5E,22,65,30,4F,50,63,61,73,66,6C,3A,48,6E,5A,72,31,4B,64,49,
> 2009-07-07 19:56:58.252 59,55,73,4D,61,2B,60,27,6E,38,6F,53,23,69,39,73,23,74,2C,2F,23,4B,35,30,31,
> 2009-07-07 19:56:58.252 28,2B,2A,3B,5B,63,34,3B,3C,6C,2A,63,3A,66,37,53,45,6A,5C,25,5D,72,45,62,24,
> 2009-07-07 19:56:58.252 60,67,37,6C,60,47,6F,3E,5A,5A,72,2E,73,5E,49,74,71,26,6F,61,2B,60,27,6E,62,
> 2009-07-07 19:56:58.252 32,67,28,3A,48,3C,4D,62,59,5F,37,72,3E,66,5E,23,51,74,45,43,2A,62,68,6C,58,
> 2009-07-07 19:56:58.252 4A,54,24,31,60,74,5E,42,70,63,47,67,6D,63,67,39,24,4D,31,3D,67,31,27,62,33,
> 2009-07-07 19:56:58.252 3B,5D,53,3C,36,35,2C,5E,2F,27,5C,34,35,42,27,4A,3D,43,47,53,47,5B,5C,28,48,
> 2009-07-07 19:56:58.252 3D,66,3E,38,43,64,74,25,67,44,4C,5C,50,48,68,49,22,4F,46,4C,47,4A,59,26,3E,
> 2009-07-07 19:56:58.252 67,37,29,36,34,70,42,30,4D,2F,63,3C,5A,4A,67,24,53,28,28,29,71,48,2A,3F,27,
> 2009-07-07 19:56:58.252 61,72,41,3D,6E,4E,3F,5D,47,51,25,2F,5F,34,3F,2C,23,25,54,69,42,26,4C,2B,71,
> 2009-07-07 19:56:58.252 41,39,26,21,38,6A,6F,4F,4F,47,70,2C,51,28,54,2D,25,73,35,6C,70,4B,51,61,6B,
> 2009-07-07 19:56:58.252 74,2A,59,46,45,28,48,30,74,53,71,33,23,46,2C,3B,27,70,35,3B,46,57,5C,6C,2A,
> 2009-07-07 19:56:58.252 67,49,3E,5A,3F,2A,43,29,60,46,40,4A,41,69,2C,45,67,29,35,39,48,21,26,51,47,
> 2009-07-07 19:56:58.252 6A,6E,30,4A,61,28,37,59,72,41,3E,44,24,40,71,26,47,4C,4F,32,68,4F,22,42,4F,
> 2009-07-07 19:56:58.252 4E,72,5B,26,47,58,51,52,3A,4D,43,41,58,75,26,50,72,3A,5B,6A,44,62,72,36,23,
> 2009-07-07 19:56:58.252 21,2A,74,55,22,56,41,64,71,46,63,5F,62,41,64,4D,58,63,60,21,28,5C,2F,3F,69,
> 2009-07-07 19:56:58.252 4C,6D,21,2A,46,40,4A,71,59,2B,48,68,2A,41,6D,59,3E,6D,52,62,58,3C,53,3A,2D,
> 2009-07-07 19:56:58.252 68,36,56,5B,46,40,4F,4A,42,2B,48,64,51,32,6D,59,3E,6D,52,39,4E,56,3A,58,59,
> 2009-07-07 19:56:58.252 3A,47,24,63,50,60,61,37,49,47,6E,21,31,34,2E,2C,4F,6F,61,63,41,3A,5D,71,37,
> 2009-07-07 19:56:58.252 2E,4E,30,6D,50,28,43,6F,37,3D,56,3C,75,3F,4C,61,40,58,2E,51,42,42,49,4B,61,
> 2009-07-07 19:56:58.252 56,37,2D,60,2D,66,34,66,60,63,41,34,49,73,37,2E,4D,62,5F,72,4B,2C,3C,5C,57,
> 2009-07-07 19:56:58.252 3E,53,2B,70,2F,33,60,71,53,53,49,6D,59,3B,4A,45,36,25,6D,2B,25,5C,36,37,29,
> 2009-07-07 19:56:58.252 29,39,4E,6B,38,3C,2C,21,4A,31,37,22,27,4A,4C,66,6C,23,6C,45,61,37,6E,29,55,
> 2009-07-07 19:56:58.252 6D,72,67,29,36,3F,61,3D,45,5A,3F,75,30,2C,51,52,55,63,4B,46,38,35,3A,57,71,
> 2009-07-07 19:56:58.252 39,6D,55,2C,3D,38,59,2C,25,63,6A,6B,37,51,3D,25,71,41,35,3C,30,6E,72,22,2A,
> 2009-07-07 19:56:58.252 61,5A,3A,22,53,74,73,4E,64,3C,70,65,3F,38,63,44,75,56,49,56,44,23,4B,2F,39,
> 2009-07-07 19:56:58.252 2B,74,40,45,6C,69,5A,37,29,51,6F,46,6A,59,63,4C,67,6D,43,67,67,50,25,59,59,
> 2009-07-07 19:56:58.252 2F,71,5F,3C,72,48,29,36,4B,32,35,65,64,2E,72,72,29,2C,47,58,68,23,4B,5D,32,
> 2009-07-07 19:56:58.252 58,2B,4C,27,5C,25,2F,52,35,61,40,53,3D,2D,2B,2F,3D,68,71,6D,2C,6C,50,61,5C,
> 2009-07-07 19:56:58.252 2A,74,26,37,55,36,40,5E,5D,22,3F,42,55,38,6A,45,42,63,6F,2A,67,3A,74,36,3A,
> 2009-07-07 19:56:58.252 3A,72,30,51,5C,4C,40,26,45,4F,47,64,5C,27,4E,73,47,28,55,50,21,44,5D,32,2B,
> 2009-07-07 19:56:58.252 5C,71,23,64,33,53,63,59,57,2A,4B,54,24,5D,2B,40,5B,27,70,32,29,2E,2F,72,33,
> 2009-07-07 19:56:58.252 3E,65,27,43,61,35,55,3E,22,2B,65,30,59,66,4C,65,30,2C,3C,61,56,35,3A,36,6A,
> 2009-07-07 19:56:58.252 4A,5B,59,55,26,39,44,21,31,50,49,54,72,28,56,62,6F,6C,42,35,65,38,3B,3E,5B,
> 2009-07-07 19:56:58.252 4E,47,67,27,22,2D,34,71,4B,23,70,4F,71,66,6E,55,64,3A,34,6A,6E,62,6C,2A,6D,
> 2009-07-07 19:56:58.252 53,24,6F,2B,55,24,64,62,2F,30,5A,5F,34,5C,47,56,3D,50,2D,32,60,4E,31,48,22,
> 2009-07-07 19:56:58.252 43,63,36,57,45,3D,74,34,6E,48,24,3D,2F,4D,64,30,57,23,68,2D,54,56,4F,4F,34,
> 2009-07-07 19:56:58.252 61,5C,29,31,68,6E,73,2A,2C,56,4C,6C,42,2C,42,24,56,53,39,69,55,5D,32,70,54,
> 2009-07-07 19:56:58.252 26,26,3B,37,6A,2B,30,60,44,2D,49,6A,34,64,6E,58,4A,2F,51,4E,6C,4D,5B,71,6D,
> 2009-07-07 19:56:58.252 4B,5B,6C,31,62,64,2F,48,46,60,71,4B,22,50,49,26,39,43,4C,2C,5F,3B,3E,33,4B,
> 2009-07-07 19:56:58.252 3A,45,40,42,6E,29,4F,35,72,26,3F,68,45,44,26,72,39,5B,4E,61,4E,3B,72,2C,3D,
> 2009-07-07 19:56:58.252 27,61,66,3C,23,59,3F,2D,63,6C,4F,59,46,60,26,23,22,32,4B,68,26,6B,2D,4C,25,
> 2009-07-07 19:56:58.252 57,74,4C,69,68,2A,44,4F,5E,4F,38,26,30,5E,54,67,66,61,47,34,59,60,4B,34,5C,
> 2009-07-07 19:56:58.252 4A,56,55,4B,33,2D,57,26,66,2C,53,37,3B,30,4F,48,5D,4D,3D,31,5C,6E,5D,3E,34,
> 2009-07-07 19:56:58.252 30,44,3F,4A,40,66,66,34,45,2D,4E,3D,57,29,3B,5F,6F,5A,4D,58,23,52,5C,48,40,
> 2009-07-07 19:56:58.252 66,66,34,45,6A,6F,63,68,54,72,55,54,41,2D,42,2C,72,2B,23,27,44,25,3F,4A,4B,
> 2009-07-07 19:56:58.252 43,74,53,48,6F,37,4F,4F,5C,6B,23,6F,6B,22,4B,4F,37,34,45,31,4D,4C,63,73,33,
> 2009-07-07 19:56:58.252 4C,5A,63,61,5C,6B,41,46,42,5E,44,3D,2A,31,44,25,6C,42,4E,2A,52,55,23,74,28,
> 2009-07-07 19:56:58.252 3D,55,34,60,47,43,47,2D,40,6F,54,61,28,5D,68,44,4B,41,24,2B,29,5D,5F,3B,27,
> 2009-07-07 19:56:58.252 37,58,73,67,39,4E,57,49,6F,26,5B,51,5C,43,6C,45,4E,4B,4D,49,3A,66,63,5D,3C,
> 2009-07-07 19:56:58.252 31,52,5B,66,2B,4F,74,60,60,66,6E,34,24,4B,3C,3F,54,5E,31,30,66,2B,54,60,6D,
> 2009-07-07 19:56:58.252 5B,45,51,21,63,2D,50,47,4B,33,5B,29,52,3F,23,29,5E,52,70,4E,23,5C,57,55,5E,
> 2009-07-07 19:56:58.252 3D,64,68,36,53,42,29,5D,38,50,2A,67,66,51,50,60,4F,64,22,71,25,23,2A,21,55,
> 2009-07-07 19:56:58.252 65,3E,31,3A,25,38,6F,43,61,59,45,54,5D,67,36,58,3A,3C,5C,44,32,40,62,73,44,
> 2009-07-07 19:56:58.252 32,73,69,66,4D,62,6C,4E,57,57,28,55,54,33,25,38,75,25,59,59,45,55,69,32,2C,
> 2009-07-07 19:56:58.252 40,28,71,67,42,6F,71,6D,3E,2A,30,28,64,69,46,2F,32,48,3C,70,27,61,6A,35,5B,
> 2009-07-07 19:56:58.252 27,2C,5D,4D,64,6A,6D,74,55,60,32,6A,69,4E,49,28,34,56,6B,6A,2A,41,22,5A,55,
> 2009-07-07 19:56:58.252 47,40,56,39,2C,5C,47,31,41,6A,6B,25,67,6B,2A,25,47,53,56,38,25,4B,73,58,60,
> 2009-07-07 19:56:58.252 5A,58,42,6C,69,42,3F,69,30,35,58,66,34,44,46,40,6A,5D,32,36,2D,3E,50,33,48,
> 2009-07-07 19:56:58.252 52,4C,6E,36,23,5E,26,5F,5F,49,4E,63,6B,53,6D,64,4D,3A,4F,45,4E,66,5A,34,50,
> 2009-07-07 19:56:58.252 2A,6B,57,67,50,60,4C,55,6F,64,26,5A,5F,6F,54,33,72,3D,74,30,3E,70,22,71,53,
> 2009-07-07 19:56:58.252 3C,2A,2D,34,3E,63,65,39,53,38,5E,28,6F,6D,62,21,55,35,74,26,2A,37,4F,70,57,
> 2009-07-07 19:56:58.252 28,55,53,48,24,57,3E,68,27,68,46,22,4B,2D,66,51,63,4F,
. 2009-07-07 19:56:58.252 Sent 4122 bytes
. 2009-07-07 19:56:58.252 There are 0 bytes remaining in the send buffer
. 2009-07-07 19:56:58.252 Looking for network events
. 2009-07-07 19:56:58.252 Timeout waiting for network events
> 2009-07-07 19:56:58.252 Type: SSH_FXP_WRITE, Size: 4118, Number: 2822
> 2009-07-07 19:56:58.268 06,00,00,0B,06,00,00,00,01,30,00,00,00,00,00,00,10,00,00,00,10,00,54,51,63,
> 2009-07-07 19:56:58.268 2E,29,5F,55,63,5D,58,52,36,61,6F,56,66,49,5E,32,58,47,3F,3D,70,32,5B,6A,6E,
> 2009-07-07 19:56:58.268 26,22,2A,46,3F,32,3F,40,2D,37,5C,4A,40,48,67,26,73,23,68,61,38,63,2B,21,58,
> 2009-07-07 19:56:58.268 40,71,51,52,23,75,75,62,26,27,2A,22,69,49,6F,47,41,49,6C,42,37,4D,3B,4B,39,
> 2009-07-07 19:56:58.268 56,2F,4F,6B,4B,70,75,43,45,4C,6E,50,6B,4C,3C,29,27,6B,51,4A,5A,62,2D,45,6D,
> 2009-07-07 19:56:58.268 64,54,72,6B,24,43,5C,73,46,3B,68,57,73,25,53,47,6A,41,31,2E,3A,6D,2C,50,43,
> 2009-07-07 19:56:58.268 39,2D,4F,53,31,66,35,3C,46,59,42,6D,44,68,2D,54,56,45,73,29,67,72,3B,6E,73,
> 2009-07-07 19:56:58.268 72,6C,61,2E,59,61,34,64,5B,61,60,4F,75,5D,3D,3B,3C,59,6E,68,52,3F,42,4A,5C,
> 2009-07-07 19:56:58.268 2B,2A,64,4F,6F,29,5A,22,2B,31,70,40,53,6E,61,3F,58,6D,2A,39,3E,64,2E,5A,27,
> 2009-07-07 19:56:58.268 68,3A,2F,4A,6C,69,2B,2F,23,25,3B,50,36,2D,66,45,4B,3A,2D,52,2B,42,3E,69,50,
> 2009-07-07 19:56:58.268 3F,40,61,61,24,48,2D,3E,3B,74,43,75,62,2B,50,28,30,3B,3F,50,22,4F,68,41,55,
> 2009-07-07 19:56:58.268 37,31,74,5A,63,2E,51,51,44,60,4A,5F,67,30,4B,49,34,5C,4E,47,3E,25,40,26,5D,
> 2009-07-07 19:56:58.268 46,4F,41,41,2E,36,3F,38,54,4D,2F,5B,6C,48,26,62,39,28,6C,5B,74,4E,57,23,61,
> 2009-07-07 19:56:58.268 39,6C,72,28,54,51,57,4E,69,42,62,43,60,32,32,73,6E,68,2A,39,3D,29,21,32,3A,
> 2009-07-07 19:56:58.268 24,73,5E,40,50,2C,33,4E,36,27,72,59,39,51,46,61,2E,3E,21,74,69,4B,4A,50,5C,
> 2009-07-07 19:56:58.268 43,51,43,6A,2E,4B,2A,44,57,64,2C,35,42,41,4E,72,37,2C,39,39,58,75,60,4F,22,
> 2009-07-07 19:56:58.268 3C,33,3C,26,73,5B,24,55,41,5E,71,57,4E,61,5B,2A,2F,5C,41,4F,42,36,6D,51,47,
> 2009-07-07 19:56:58.268 5F,58,5E,2F,36,72,60,24,39,33,69,3D,62,4F,50,72,4A,2E,42,34,59,64,74,3A,61,
> 2009-07-07 19:56:58.268 58,48,3B,34,47,68,33,39,49,50,54,40,67,4B,5A,51,4E,4A,4B,33,2E,58,69,2E,61,
> 2009-07-07 19:56:58.268 2C,29,3C,3C,67,47,3F,43,50,47,4B,6C,4E,23,47,53,4C,44,37,71,5A,44,74,45,6A,
> 2009-07-07 19:56:58.268 2F,5B,32,5A,3E,68,27,3C,62,41,68,51,27,51,36,6C,68,3F,33,32,68,2A,38,51,22,
> 2009-07-07 19:56:58.268 3E,40,3B,66,47,42,34,5F,36,2F,60,56,70,53,6A,5B,2D,2D,5E,50,2D,44,32,5F,57,
> 2009-07-07 19:56:58.268 35,2B,31,65,37,45,26,36,2E,61,2E,54,6D,3C,46,5A,52,5D,23,44,4B,3D,3A,36,2D,
> 2009-07-07 19:56:58.268 4D,60,2E,29,2E,6D,4D,6D,42,6C,5B,24,58,4E,4C,44,34,6C,3D,5C,63,2A,2A,5A,3F,
> 2009-07-07 19:56:58.268 2F,29,34,51,46,5E,6E,74,4D,39,37,54,66,5F,4A,4B,5E,75,6A,43,23,46,47,41,51,
> 2009-07-07 19:56:58.268 27,5E,24,62,3A,31,66,27,6A,5A,4E,30,50,5E,55,43,55,3E,25,3A,3D,66,4F,34,6F,
> 2009-07-07 19:56:58.268 4F,6F,23,72,6C,35,42,68,70,23,67,3F,35,6B,39,35,60,59,6D,4B,3F,60,52,58,27,
> 2009-07-07 19:56:58.268 3C,58,33,33,23,22,44,35,70,56,54,21,6C,70,54,42,70,36,72,32,55,39,66,30,3B,
> 2009-07-07 19:56:58.268 75,28,40,6A,29,4A,44,56,5E,47,66,4B,4D,56,70,68,70,5C,38,3C,2E,73,6A,44,6C,
> 2009-07-07 19:56:58.268 4C,63,2F,30,5A,49,73,26,4E,39,5F,4F,66,6E,4C,5D,61,5F,72,23,6E,26,3E,3E,55,
> 2009-07-07 19:56:58.268 50,4F,34,60,36,31,6A,45,26,49,40,63,30,31,48,30,55,72,3D,32,54,33,42,64,44,
> 2009-07-07 19:56:58.268 6C,64,35,43,67,35,72,26,35,4B,21,29,71,2C,3F,32,6D,42,26,46,45,30,38,23,60,
> 2009-07-07 19:56:58.268 55,59,25,36,4E,42,30,3F,29,28,4D,64,56,65,39,33,2F,6B,4B,5C,3A,58,21,2B,72,
> 2009-07-07 19:56:58.268 43,68,2F,51,21,6E,71,75,2E,52,50,2C,3E,23,40,47,63,52,40,51,6A,70,3F,42,34,
> 2009-07-07 19:56:58.268 3D,3E,64,54,49,43,72,61,26,74,32,3E,50,31,25,25,2B,38,28,57,36,63,72,34,71,
> 2009-07-07 19:56:58.268 58,24,38,4E,36,38,59,2D,6E,5A,2C,4D,49,56,62,75,2C,32,30,31,44,55,45,35,28,
> 2009-07-07 19:56:58.268 6E,63,2A,40,52,64,3B,6C,2E,33,41,55,6A,36,38,3D,50,47,61,2D,62,6F,61,70,38,
> 2009-07-07 19:56:58.268 6E,6E,74,2B,66,5B,58,3C,31,56,75,37,4B,71,25,2B,41,57,4D,4B,74,58,53,60,6E,
> 2009-07-07 19:56:58.268 59,38,5F,2B,2B,71,6F,52,30,67,65,40,5A,50,52,64,64,74,4F,64,51,25,33,5F,59,
> 2009-07-07 19:56:58.268 3C,29,58,61,35,27,30,4F,5C,3C,53,28,45,65,68,5D,24,2A,5D,5B,69,3B,58,4A,54,
> 2009-07-07 19:56:58.268 2E,3C,4D,71,74,3D,4F,44,6E,59,35,50,4A,4D,22,71,56,41,53,72,22,3E,59,5F,35,
> 2009-07-07 19:56:58.268 3B,53,63,35,52,62,57,45,35,2C,6C,35,51,71,34,24,52,24,49,23,4E,6D,2D,60,2F,
> 2009-07-07 19:56:58.268 4C,70,34,3B,61,28,3E,35,4C,31,36,60,5D,35,46,28,3E,74,59,3A,4A,26,49,61,2A,
> 2009-07-07 19:56:58.268 5C,3B,67,3A,57,2A,5B,28,43,66,3C,4D,23,67,64,59,62,35,53,24,46,2D,54,5D,56,
> 2009-07-07 19:56:58.268 4D,4A,38,66,42,2D,53,55,49,33,72,51,5A,50,46,4D,2B,64,63,6F,44,65,5D,4A,2C,
> 2009-07-07 19:56:58.268 44,2E,34,55,60,57,2B,4E,4C,5B,62,34,38,62,51,72,6E,5D,6A,5B,34,51,44,2E,2D,
> 2009-07-07 19:56:58.268 3B,28,29,60,5D,52,73,72,2D,63,5D,70,22,39,5B,21,65,26,32,73,21,44,37,49,6A,
> 2009-07-07 19:56:58.268 6A,49,40,70,61,49,6D,6C,3A,5F,27,28,34,6F,2E,67,23,29,26,4D,73,25,60,4A,4C,
> 2009-07-07 19:56:58.268 4D,5D,23,56,23,70,38,44,60,3A,3C,2D,6F,42,41,75,38,37,31,5B,74,36,2F,3F,39,
> 2009-07-07 19:56:58.268 4E,38,4A,46,6E,63,54,63,52,43,4A,3F,66,26,5C,4C,3B,69,28,44,4D,73,70,47,61,
> 2009-07-07 19:56:58.268 73,65,64,62,2A,49,2F,3F,29,51,6F,40,47,59,3A,2C,6F,74,29,30,73,69,4D,50,52,
> 2009-07-07 19:56:58.268 6D,3C,5C,21,74,6F,5C,51,2B,4E,31,3D,4A,31,4C,31,51,61,62,29,54,68,5A,33,22,
> 2009-07-07 19:56:58.268 5B,74,3D,2D,41,3C,6C,6A,69,6F,4C,4C,71,6B,33,69,23,44,43,74,56,4F,4C,4D,62,
> 2009-07-07 19:56:58.268 64,70,29,59,3F,2E,36,4E,29,30,6F,23,71,50,52,6D,3C,4C,22,72,2D,5A,52,72,29,
> 2009-07-07 19:56:58.268 45,41,2C,5A,53,49,73,5B,3F,66,21,61,55,31,5C,29,3C,3B,2E,33,49,51,67,26,31,
> 2009-07-07 19:56:58.268 48,5D,3A,6F,69,23,22,52,3D,65,28,6A,41,49,50,70,31,53,62,67,38,45,75,56,4C,
> 2009-07-07 19:56:58.268 34,33,4F,3A,3C,58,48,6A,6E,49,24,55,54,69,5E,32,4B,69,6E,62,50,58,5B,3A,2D,
> 2009-07-07 19:56:58.268 68,3F,5C,72,34,27,6E,4D,3B,37,56,48,48,5F,46,2A,5C,5B,6C,52,3F,49,55,37,63,
> 2009-07-07 19:56:58.268 26,32,40,6A,5B,36,5C,6E,22,32,75,36,64,35,24,64,21,5C,54,38,2E,34,4B,5B,2F,
> 2009-07-07 19:56:58.268 4F,65,37,5C,70,6A,52,5A,3E,40,4F,61,4E,6D,6F,27,5F,6E,60,49,48,5B,56,4B,70,
> 2009-07-07 19:56:58.268 2E,62,67,68,53,52,73,73,60,50,5B,50,71,70,4C,68,29,3A,5A,3A,73,42,59,55,73,
> 2009-07-07 19:56:58.268 67,38,46,5E,32,29,6B,4D,4B,3F,2A,5A,55,5A,31,52,41,3E,3E,41,4B,3B,69,70,38,
> 2009-07-07 19:56:58.268 56,22,6F,51,51,43,58,66,54,33,46,60,67,34,74,2E,2E,68,49,64,23,33,41,32,2C,
> 2009-07-07 19:56:58.268 21,66,41,54,29,53,5A,3E,70,3F,6B,5A,51,34,2D,2E,21,3E,53,64,69,39,44,2C,2A,
> 2009-07-07 19:56:58.268 53,62,38,4E,47,55,46,62,2D,6D,52,5E,74,4F,45,5C,74,39,3F,5D,6E,50,35,65,25,
> 2009-07-07 19:56:58.268 4B,58,34,5C,75,24,3A,59,63,23,5E,38,6C,66,42,4B,29,63,60,66,71,30,48,4F,61,
> 2009-07-07 19:56:58.268 2D,6D,2E,42,5D,63,5C,62,72,32,50,59,40,52,31,50,3A,68,4E,29,41,26,46,49,57,
> 2009-07-07 19:56:58.268 25,58,4A,39,53,63,2D,6F,57,32,53,70,6A,5D,5F,6E,49,4C,42,23,47,6D,73,32,71,
> 2009-07-07 19:56:58.268 37,4A,69,68,6F,28,55,3E,27,34,52,29,4A,25,3F,4E,29,49,48,6C,28,69,3C,61,75,
> 2009-07-07 19:56:58.268 3F,34,4B,68,6E,5F,65,27,56,6A,23,37,56,3B,6F,68,4E,52,28,35,5E,57,48,2E,5A,
> 2009-07-07 19:56:58.268 54,50,5B,41,71,54,42,3A,26,57,3C,6D,6A,52,5C,27,2B,64,23,2D,71,6C,2E,2F,2D,
> 2009-07-07 19:56:58.268 3D,37,5E,31,45,73,50,48,45,2D,74,2C,4B,67,44,50,22,65,60,48,3A,5B,40,26,60,
> 2009-07-07 19:56:58.268 6C,5E,66,33,40,56,6C,6A,5F,38,39,75,4A,4E,6E,49,41,5C,31,31,43,68,4C,25,3F,
> 2009-07-07 19:56:58.268 36,44,44,37,41,55,6A,71,63,46,54,24,72,6C,66,52,60,2F,64,38,40,75,73,52,4D,
> 2009-07-07 19:56:58.268 39,3A,70,40,2A,39,39,54,38,26,3D,2C,68,42,30,6E,2D,4E,48,3E,40,67,3A,56,46,
> 2009-07-07 19:56:58.268 6C,73,5F,4D,62,6D,4C,39,4E,2F,31,49,30,71,32,40,69,64,27,24,3D,69,54,42,36,
> 2009-07-07 19:56:58.268 6E,5F,4E,3D,42,53,42,2B,59,74,30,44,6F,4D,50,48,71,23,3F,49,5E,68,56,28,38,
> 2009-07-07 19:56:58.268 37,3F,58,34,56,2B,44,5E,4F,56,2A,4B,6F,62,61,50,2B,4E,3B,6C,2E,51,6B,37,3C,
> 2009-07-07 19:56:58.268 67,22,73,27,6F,39,4E,71,6E,31,23,21,4D,56,2F,64,3C,3C,34,5D,64,31,39,39,5D,
> 2009-07-07 19:56:58.268 60,26,5D,4D,5A,61,5A,6F,33,27,25,44,5B,3C,27,3C,24,48,26,4F,27,3A,46,6F,34,
> 2009-07-07 19:56:58.268 59,2D,3C,29,36,6A,47,75,36,64,43,4A,6E,27,39,43,49,71,6E,25,37,60,67,64,68,
> 2009-07-07 19:56:58.268 75,22,72,54,55,5A,5E,2A,4F,6C,30,4D,41,3B,4A,52,3C,51,35,2C,69,4B,23,72,3B,
> 2009-07-07 19:56:58.268 2A,61,6A,59,3F,74,2D,63,39,67,6F,63,21,56,5A,6D,3E,63,2D,26,3E,58,41,65,23,
> 2009-07-07 19:56:58.268 43,2C,43,66,65,58,63,65,5F,2B,75,70,4F,23,3F,2F,49,5B,4C,64,62,44,60,45,61,
> 2009-07-07 19:56:58.268 68,46,3B,47,27,6D,63,43,59,47,57,52,3E,58,41,4D,62,73,46,3F,38,21,6D,49,39,
> 2009-07-07 19:56:58.268 3D,41,3E,43,5E,54,75,60,66,3F,41,2A,30,59,59,32,5F,50,6A,49,6D,24,4C,44,52,
> 2009-07-07 19:56:58.268 74,38,39,6D,46,4E,37,4D,52,67,3C,2C,22,28,3A,23,3B,71,52,3F,49,37,21,44,3D,
> 2009-07-07 19:56:58.268 72,31,4D,5D,25,3E,6A,38,54,29,4F,2D,6C,58,3E,6A,22,3C,6C,34,63,70,4E,31,61,
> 2009-07-07 19:56:58.268 3D,31,69,64,52,3A,71,3E,27,37,48,5A,61,4F,38,46,52,25,3D,73,75,23,24,4B,40,
> 2009-07-07 19:56:58.268 68,41,55,27,25,22,6B,25,28,23,48,35,6C,36,36,48,3E,6B,67,63,64,4F,51,50,27,
> 2009-07-07 19:56:58.268 6D,72,45,26,53,50,5F,4B,3D,66,40,59,4F,50,37,60,56,24,2C,2E,47,6C,6C,5A,3D,
> 2009-07-07 19:56:58.268 4B,53,5C,35,51,70,5B,24,3D,30,47,23,74,25,5E,27,2E,38,53,23,28,29,73,2E,65,
> 2009-07-07 19:56:58.268 48,3E,2E,23,49,2D,5C,74,2B,6E,49,2A,31,60,28,4B,5E,45,23,58,66,65,73,67,4C,
> 2009-07-07 19:56:58.268 6D,42,5F,5A,3B,33,65,30,4A,6F,48,68,21,53,67,60,2E,2A,42,56,30,48,64,58,39,
> 2009-07-07 19:56:58.268 5F,48,75,24,43,52,28,2B,36,23,37,2E,3B,61,23,73,63,41,3B,6F,51,60,5E,36,72,
> 2009-07-07 19:56:58.268 34,3D,4C,24,4B,60,2D,3E,67,52,5E,6B,74,63,37,74,68,6D,37,26,6D,2A,64,66,63,
> 2009-07-07 19:56:58.268 6D,29,4C,47,6E,5E,74,58,2C,6C,38,68,69,2B,73,3D,71,6E,31,52,4B,58,4D,37,4E,
> 2009-07-07 19:56:58.268 64,3A,6B,54,4C,5A,5F,55,31,64,2D,66,6B,48,24,60,27,43,48,48,6C,3F,64,62,5B,
> 2009-07-07 19:56:58.268 2B,29,49,49,5B,26,3B,49,43,5F,3D,4A,26,34,3A,32,45,6D,3B,4C,4C,3B,25,26,50,
> 2009-07-07 19:56:58.268 31,73,55,33,4C,44,39,53,37,4E,5F,62,45,67,63,64,29,61,60,50,72,30,4F,59,52,
> 2009-07-07 19:56:58.268 35,44,4F,2D,5A,58,3C,4A,3C,5C,4C,26,4E,5D,24,4D,57,5D,2A,51,2F,5D,6F,40,2A,
> 2009-07-07 19:56:58.268 47,43,3D,26,30,66,58,50,2C,37,6F,44,59,44,50,2A,5D,27,40,55,66,4E,62,61,39,
> 2009-07-07 19:56:58.268 33,43,4A,4D,24,63,44,2C,70,3C,35,53,23,46,68,39,3F,5D,24,4F,4E,21,46,36,23,
> 2009-07-07 19:56:58.268 37,2D,5C,22,41,33,3B,4F,35,6D,51,59,75,5D,35,29,75,65,3C,29,5E,23,5E,52,4C,
> 2009-07-07 19:56:58.268 57,6B,64,2B,3D,5A,47,6F,55,6E,41,64,5E,2D,51,73,25,70,2D,5A,35,51,6D,3C,33,
> 2009-07-07 19:56:58.268 5C,2E,5A,26,5C,4E,61,54,70,34,52,59,48,4E,3A,6F,35,40,5B,39,2B,35,33,2D,21,
> 2009-07-07 19:56:58.268 66,5D,43,2C,4C,33,36,63,3D,59,24,36,3F,60,69,6E,4E,67,29,5B,58,38,70,6B,25,
> 2009-07-07 19:56:58.268 48,21,75,5B,46,34,3C,56,29,56,54,4E,36,3A,26,3E,31,50,6C,50,40,3F,65,44,69,
> 2009-07-07 19:56:58.268 63,3E,51,35,36,24,52,23,5A,30,54,46,6C,67,52,65,66,3C,72,25,5D,70,49,38,6C,
> 2009-07-07 19:56:58.268 35,71,62,24,33,4D,2E,57,2F,45,43,28,6D,3A,56,2D,59,62,6A,56,4F,37,40,6B,2B,
> 2009-07-07 19:56:58.268 2C,36,2B,35,3E,3C,64,69,28,59,67,35,5F,4B,69,66,55,36,24,49,46,61,45,63,71,
> 2009-07-07 19:56:58.268 33,71,29,4C,64,66,41,6C,31,63,6B,33,31,5D,4D,47,3A,49,6C,70,63,62,45,41,53,
> 2009-07-07 19:56:58.268 2D,4B,60,45,60,2E,5D,5E,4B,24,40,37,37,2A,3C,64,5E,66,53,66,2B,64,3D,56,61,
> 2009-07-07 19:56:58.268 33,64,42,66,63,42,67,24,46,51,40,53,56,45,56,5C,6A,2C,3D,74,35,62,36,50,61,
> 2009-07-07 19:56:58.268 69,46,73,4F,5E,4C,28,44,3B,4C,2A,6F,4C,51,55,75,3E,3E,55,62,5C,37,21,50,3C,
> 2009-07-07 19:56:58.268 70,66,35,65,2D,41,53,71,6D,6E,72,74,48,65,3D,33,52,3D,6A,65,5A,27,6F,3B,4E,
> 2009-07-07 19:56:58.268 4F,3E,21,29,5E,2E,65,3C,44,2E,5B,2D,24,65,4A,50,4C,37,22,63,5E,56,71,2B,56,
> 2009-07-07 19:56:58.268 6B,42,3D,22,3D,39,3D,57,4D,4C,40,4C,5E,4C,3F,46,3D,5F,47,6C,61,38,25,27,4F,
> 2009-07-07 19:56:58.268 6D,32,74,3A,66,28,26,38,5A,65,29,2B,4E,70,33,56,6D,5D,56,50,49,67,26,68,24,
> 2009-07-07 19:56:58.268 64,46,33,4C,5F,51,2A,27,48,72,4E,24,68,44,42,69,6E,72,52,67,58,3D,3A,50,43,
> 2009-07-07 19:56:58.268 62,3D,75,39,57,4D,57,36,3B,75,69,48,54,52,31,50,3B,47,58,64,59,69,36,57,3C,
> 2009-07-07 19:56:58.268 2D,5C,4D,2C,31,48,72,5B,2C,4B,61,56,6F,4F,28,55,6C,36,2C,49,40,28,21,4E,73,
> 2009-07-07 19:56:58.268 5F,38,3C,50,3C,70,66,35,67,5E,3F,5F,68,33,4E,41,53,43,38,49,61,21,21,53,5D,
> 2009-07-07 19:56:58.268 5A,6C,30,65,3E,2B,34,46,22,3F,45,4E,2D,2A,59,6C,6D,48,48,52,3F,5A,54,27,57,
> 2009-07-07 19:56:58.268 6E,37,71,61,5D,2D,47,3D,40,4D,28,4D,51,53,2E,54,3D,52,63,44,53,3B,3D,49,61,
> 2009-07-07 19:56:58.268 3F,2A,64,5D,4E,40,6A,26,24,46,2A,2E,4B,5B,3E,4C,60,53,54,4B,71,24,60,2C,38,
> 2009-07-07 19:56:58.268 4D,47,3E,32,2A,49,22,74,71,4E,3B,47,4B,6E,32,27,2D,61,2D,70,28,33,67,53,49,
> 2009-07-07 19:56:58.268 74,60,2E,26,50,5C,4F,38,36,25,6A,38,56,4C,64,63,6F,6C,35,74,55,31,5F,2C,47,
> 2009-07-07 19:56:58.268 31,2E,51,6D,69,48,2B,66,5C,67,74,39,65,39,61,5C,30,73,64,28,22,74,72,3B,2A,
> 2009-07-07 19:56:58.268 66,75,43,42,30,6E,2E,39,6B,25,5D,32,50,56,59,5A,47,66,4D,64,53,73,36,4E,24,
> 2009-07-07 19:56:58.268 70,62,3B,5E,2D,21,56,4D,6A,75,5A,3E,3E,26,6B,63,44,3D,46,50,26,38,34,5B,42,
> 2009-07-07 19:56:58.268 3F,22,46,41,73,39,4C,51,67,4C,62,3E,31,72,45,5A,4F,21,6C,67,4D,22,3E,45,3E,
> 2009-07-07 19:56:58.268 72,6B,29,28,6D,66,6E,3D,21,6C,49,74,26,5E,66,22,69,24,2C,5A,49,2D,28,22,3A,
> 2009-07-07 19:56:58.268 5D,29,2D,65,3B,3E,6D,33,2D,51,73,25,6F,42,24,66,49,4C,4C,5B,41,2E,35,33,27,
> 2009-07-07 19:56:58.268 26,2B,23,57,3A,46,5A,50,4E,21,26,30,68,26,37,5B,5B,4D,5F,74,24,41,59,6E,30,
> 2009-07-07 19:56:58.268 6A,71,2D,4E,6A,75,73,26,56,2A,49,3A,2B,2B,32,66,23,41,65,5A,61,46,65,21,39,
> 2009-07-07 19:56:58.268 4B,75,27,2F,69,21,4D,72,32,27,39,6D,56,3A,3D,47,6B,60,31,2C,2B,2A,42,4F,38,
> 2009-07-07 19:56:58.268 2B,6A,68,4A,64,4C,4F,64,26,37,5B,5B,65,5F,74,24,42,64,6E,36,4A,35,4B,51,71,
> 2009-07-07 19:56:58.268 72,48,68,45,5E,23,3A,36,53,3D,46,24,60,2C,57,4C,25,35,63,51,33,54,24,5F,5A,
> 2009-07-07 19:56:58.268 71,61,43,48,6C,75,6F,59,30,38,26,69,3B,38,46,54,6E,4B,69,65,4E,42,75,23,61,
> 2009-07-07 19:56:58.268 46,70,48,4E,38,5E,21,30,62,39,71,6B,56,47,50,4E,35,6B,6D,57,3C,33,2F,53,3D,
> 2009-07-07 19:56:58.268 43,2B,21,24,74,6A,27,50,34,70,68,36,30,6A,6E,23,55,5A,49,23,22,43,5C,35,3C,
> 2009-07-07 19:56:58.268 30,68,28,28,66,26,23,52,48,6B,51,27,75,62,69,5D,54,38,24,32,5B,2E,2A,65,3E,
> 2009-07-07 19:56:58.268 4D,46,32,29,38,6B,5E,2C,71,60,31,41,2E,34,6B,56,32,2B,26,30,50,53,2E,54,3E,
> 2009-07-07 19:56:58.268 3D,4C,51,31,27,2E,4C,35,22,63,60,38,38,6F,46,41,6C,66,35,75,6C,70,45,69,57,
> 2009-07-07 19:56:58.268 41,5D,33,48,6B,39,64,49,6A,68,67,52,6B,4E,70,47,40,67,50,63,26,6E,2D,58,3E,
> 2009-07-07 19:56:58.268 53,50,37,4F,3E,33,38,5D,36,32,3F,4A,71,45,42,55,72,36,6B,2A,6C,28,31,57,65,
> 2009-07-07 19:56:58.268 31,2A,2E,48,6B,39,64,49,34,69,3F,68,2E,4E,70,42,68,5C,35,2A,4D,74,3B,4B,6F,
> 2009-07-07 19:56:58.268 47,21,37,25,2A,4E,39,45,59,25,4A,69,6C,69,38,5D,60,5A,56,71,28,70,6C,71,26,
> 2009-07-07 19:56:58.268 6D,5B,72,5E,3F,33,2D,3F,27,60,62,33,2F,41,2D,3B,73,2D,63,30,66,58,30,65,58,
> 2009-07-07 19:56:58.268 29,34,5B,4A,3B,3F,4D,4F,34,5B,5A,75,5A,6E,5C,30,4D,33,3F,4D,55,56,59,43,6F,
> 2009-07-07 19:56:58.268 54,2D,33,40,6C,4F,5E,37,4F,2B,52,4E,21,3C,31,66,2B,37,4A,3A,31,6A,66,55,2C,
> 2009-07-07 19:56:58.268 65,66,58,68,27,38,46,5D,29,5B,3F,51,33,61,6E,5B,28,21,45,29,28,21,65,23,4A,
> 2009-07-07 19:56:58.268 6A,41,48,31,27,2E,4B,3C,4C,51,2D,72,55,5A,47,2C,2C,3F,47,49,5C,4A,21,67,73,
> 2009-07-07 19:56:58.268 5C,36,2E,6F,3E,67,58,35,5D,4F,22,24,62,60,4B,51,63,55,5E,32,3C,23,72,64,71,
> 2009-07-07 19:56:58.268 45,4F,45,63,6E,74,3A,5D,39,70,60,2D,22,6D,3F,37,39,64,67,42,39,39,4C,6D,2B,
> 2009-07-07 19:56:58.268 44,26,3A,4A,43,69,2C,3E,6A,69,6E,6A,69,2D,64,66,54,2D,21,63,73,6E,26,60,66,
> 2009-07-07 19:56:58.268 46,6C,29,52,41,55,29,31,57,39,61,3E,26,63,5C,2C,44,52,4F,68,47,4F,42,26,2D,
> 2009-07-07 19:56:58.268 25,72,6E,3B,3D,66,34,46,26,48,3F,2E,3B,5C,5B,6A,37,65,3A,43,3D,3F,74,64,27,
> 2009-07-07 19:56:58.268 42,2B,38,2C,47,40,39,56,31,45,64,4D,57,3F,6B,6B,68,3B,3E,55,4F,6C,31,60,24,
> 2009-07-07 19:56:58.268 2F,30,5D,56,57,57,57,6A,46,4F,2C,56,42,4B,4E,27,2A,72,4A,53,69,6C,57,55,54,
> 2009-07-07 19:56:58.268 3B,31,4A,24,2C,36,3C,2E,42,36,6D,49,33,37,3D,6E,5A,2E,38,50,52,5A,6C,56,22,
> 2009-07-07 19:56:58.268 30,37,6D,6F,43,4C,49,75,5C,6C,29,3D,21,24,46,33,34,4C,58,2C,3F,28,3B,37,57,
> 2009-07-07 19:56:58.268 23,5F,4C,36,37,62,49,21,43,33,69,59,4D,39,5F,56,35,3A,37,34,3B,29,2F,63,61,
> 2009-07-07 19:56:58.268 30,54,4B,41,41,66,5C,51,23,65,3A,3A,59,29,62,72,53,27,
. 2009-07-07 19:56:58.268 Sent 4122 bytes
. 2009-07-07 19:56:58.268 There are 0 bytes remaining in the send buffer
Thanks. Have you tried 4.2.x beta yet? If it does not work, can you also post a log file from 4.0.7 version (for the same operation/file as you did for 4.1.9). Thanks.
